vinbags44 Posted August 4, 2020 Share Posted August 4, 2020 What Temps are recommended for applying and removal?? ..im doing a car tomorrow..it will be in garage but temps are supposed to be close to 90 degrees.. Link to comment Share on other sites More sharing options...
0 RayS Posted August 5, 2020 Share Posted August 5, 2020 5 hours ago, vinbags44 said: What Temps are recommended for applying and removal?? ..im doing a car tomorrow..it will be in garage but temps are supposed to be close to 90 degrees.. As long as you are out the sun and the sun can't hit the vehicle from the windows or open garage door, you're good to 95 that I can confirm. The humidity can make a different in the drying time and I know from experience that 90+ with 80% humidity makes for a long hot day, but it can be done. As for the low temp side, I always make sure my garage is at 55 or above before applying a coating or even a sealant, anything below that seem to take way too long to cure. kaj41354 1 Link to comment Share on other sites More sharing options...
0 vinbags44 Posted August 5, 2020 Author Share Posted August 5, 2020 35 minutes ago, RayS said: As long as you are out the sun and the sun can't hit the vehicle from the windows or open garage door, you're good to 95 that I can confirm. The humidity can make a different in the drying time and I know from experience that 90+ with 80% humidity makes for a long hot day, but it can be done. As for the low temp side, I always make sure my garage is at 55 or above before applying a coating or even a sealant, anything below that seem to take way too long to cure. Ok great. Hopefully I'll be good to go and check as I apply..thanks! Link to comment Share on other sites More sharing options...
0 Dan@Adams Posted August 5, 2020 Share Posted August 5, 2020 Ideal would be in the 65-75 F range for comfort and ease of application, but as Ray mentioned, it can be applied in higher temperature conditions. Humidity plays a factor in how the coating flashes and wipes away from the surface, so I use a window A/C unit to bring down the temperature and pull some of the humidity out of my garage, especially during these very hot summer months. Link to comment Share on other sites More sharing options...
0 JDS Posted August 16, 2020 Share Posted August 16, 2020 How about Graphene coating? Can it be applied during summer high temperatures? Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted August 16, 2020 Share Posted August 16, 2020 1 hour ago, JDS said: How about Graphene coating? Can it be applied during summer high temperatures? The same goes for Graphene just as mentioned above about Ceramic Coating. Link to comment Share on other sites More sharing options...
0 vinbags44 Posted August 16, 2020 Author Share Posted August 16, 2020 I did a black car with the graphine in about 87 degrees in the shade..had no issues..flashed a little faster than normal but came off nice and easy..graphine is great stuff..car came out amazing and water doesn't know what to do when it on there! kaj41354 1 Link to comment Share on other sites More sharing options...
vinbags44
6 answers to this question
