Can you spray Spray Graphene directly onto surfaces?
Sandalwood
2 answers to this question
Yes you can, but the overspray and places that you cannot get with the sponge or towel may result in some places showing high stops or gaps.  In addition, if you were not able to prepare the surface, that means there could be dirt, waterspots, etc., that end up under the coating.   For the best results on wheels, take them off the vehicle, clean and prep them, then coat them.   Otherwise only do what you can see, prepare and coat with quality.
Good advice from @RayS above.
You can use the interior swabs for lugnuts and other small areas, and for the best results on the wheel barrels, remove the wheels and fully prep the surface.
https://adamspolishes.com/collections/interior-cleaning-accessories/products/adam-s-interior-detailing-swabs-15-pack
