PC Speed 6
Osok
I just got done giving my charger lots of love. Started lastnight with strip wash, clay, foam, and orange pad+ shr. Finished the buffing around 1:30am. Got up this morning and finished the white+FMP and then gray+MSW. VRT on tires and trim, glass cleaner on the windows. Basically the full Adams service.
Anyways, lastnight while I was mindlessly buffing away I was wondering to myself why is it it's not good to use speed 6 with the PC? Yes it does seem quite a bit faster than 5 for some reason, but I was just wondering what the pros thought as to why are supposed to work on speed 5. :pc:
9 answers to this question
Funny stuff here guys...but only in that it's all true. For the heck of it I fired up speed 6 a couple times today while doing my brothers Marano. Oh momma does it vibrate a lot, definitely is real noisy, and for sure felt like it at times like it wanted to race off out of my hands.
Dylan...so the orange + SHR won't really cut better or faster at 6 speed? Interesting to know it's not worth the efforts.
if you want to use speed six you need the 6" counter weight to help with the vibrations. the vibrations will cause the velcro on the backing plate to wear out because with all the vibration the pad and backing plate stick and unstick at a high rate, the pad won't fly off as long as you're applying enough pressure and keeping the angle of the polisher exactly on top of the spot you're working but it will cause the backing plate to wear out. this is what Ashley told me
