Storing My Car
DP 08 GXP
well this is the first time i get to put my car into storage for the winter...i found a nice winter beater for $500 lol....my question is what do i all need to do before i tuck her away for the winter? any and all input is appreciated! :thumbsup:
Ive been storing my 93 Cobra for 7 years now. I fill the tank and add Stabil. I have it up on 4 jackstands so I dont flat spot the tires. I do disconnect the neg cable and charge the battery when I get ready to start it. Its covered with a California Car Cover and there are tire protectors on the rims and tires.
Thats all I do and Ive never had any problems since Ive been doing it this way
I agree with COBRA1993SVT except for one detail. I would get a Battery Tender and use it to keep the battery at full charge rather than disconnecting the battery. I've had my OEM battery for over 7 years and keep it on a Battery Tender whenever the car will not be driven for 3 or 4 days.
+1 on the Deltran Battery Tender Jr! Been using them for YEARS on my truck and bikes...
My '98 F150 4X4 has the original battery in it. I took delivery of it in September of '97 so it's 13 years old!
Chris
My Corvette is twelve years old and is stored for 5 months a year. First, I make sure it is spotless. Second, the gas tank is full to prevent the fuel pump from rusting. I do not use any Stabil. I tried it in one of my motorcycles and it missed up the injectors. I park my car in a barn with a dirt floor, so I place plywood under the car. The plywood will suck the moisture out of the ground and prevent rust of my frame. The plywood started as 3/8", now it's about 5/8". I don't use jack stands because I have Run Flat tires and the wheels do not flat spot. Then I pull the battery and place it in my basement on a wooden shelf and put a battery tender on it. Before I close the doors I place three moisture absorbing bags in the car. And finally put my cover on it.
I have never had a problem in 12 years.
ok looks like ill be getting the battery tender..it looks like their is a regular tender and a jr.....any advantage to either one or doesnt it matter? i plan on giving it a nice wash and clay before i store it along with a coat of MSW....i will also use the stabilin a full tank...i also am changing the oil because it needs it and i heard its a good idea to get fresh oil in there...i use amsoil but i was thinking of using a cheaper synthetic while its stored and drain it in the spring and put amsoil back in...i should be alright with the cheaper synthetic while its stored right? would i be able to get away without putting the car up on jacks or the race ramps if i up the psi on the tires and check them every so often? it is goin to be stored in the back of my father in laws building so it will get pretty chilly in there....i will also use the product to keep moisture out and maybe some moth balls to keep any criters out....i will probably also go the cheap route with some microfiber blankets sewn together to keep it covered....anything im missing? thanks again everyone!
I always get the oil changed before winter. No need to change it again in the spring. I use the Royal Purple. Fill up the gas tank. Then I give my car a good detail. Then I put a bounce sheet inside the car. Later on I'll add one to the motor and one in each tail pipe (keeps out mice). Skip the mothballs. You can also put a tennis ball in each tailpipe if mice tend to be where you store your car. You can also put the Bounce sheets under the car for mouse protection too. Then I lay down a rubber floor. I use the large rubbler blocks that snap together (like in a kindergarten room) and put down Race Ramps. The rubber floor keeps the moisture from the cement from coming up into the car and the race ramps prevent flat spots. You can get them at Lowes. I have a collector friend who puts nitrogen in his tires in the winter. Haven't tried it myself yet, but am considering it. Supposedly keeps the rubber from drying out.
Park the car on the race ramps, add the bounce sheets, hook up my little battery tender, close the hood, cover her up and tell her goodnight. Oh, and I also don't start her up till I uncover her in the spring.
thanks for the info Rich....im hopin to figure out what to do besides the race ramps cuz those are a lil pricey and i doubt the fiance would approve that purchase lol
Just get some of those rubber blocks. Even if you only put down one layer to cover entirely underneath the car. I used them for years before I got the ramps. I'd stay away from the jack idea though. Some guys swear by it, but I know too many guys that have had problems like the jacks slipping during the winter to bent axles.
that was my biggest concern....thanks again for the help Rich and everyone!
