TR6speed Posted October 16, 2010 Share Posted October 16, 2010 What is the best applicator for applying the new Brilliant Glaze. I have always applied the spray glaze with a microfiber pad, can I still use it, or should I use one of the new applicator pads from Adams? Quote Link to comment Share on other sites More sharing options...
0 AVA182 Posted October 16, 2010 Share Posted October 16, 2010 I believe they recommend the americana applicator. Quote Link to comment Share on other sites More sharing options...
0 Doug123 Posted October 16, 2010 Share Posted October 16, 2010 I have used the microfiber pad and it worked fine for me. It might absorb a little more product, but my Americana pads are isolated for Americana only, hence using my go-to microfiber pad. It is noticeably glossier than the BSG. Quote Link to comment Share on other sites More sharing options...
0 livingwater Posted October 16, 2010 Share Posted October 16, 2010 I use the microfiber applicator pad. After using it I place it in a Zip loc plastic bag, squeeze all the air out of it until it looks like it's vacuum sealed and I place it in my supply cabinet until the next time Quote Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted October 16, 2010 Share Posted October 16, 2010 Use the Americana applicator or the Red or Yellow Hex applicators. If you use a PC you can use the Grey pad as well. Quote Link to comment Share on other sites More sharing options...
0 camaro2ssblack Posted October 17, 2010 Share Posted October 17, 2010 Use the Americana applicator or the Red or Yellow Hex applicators.If you use a PC you can use the Grey pad as well.[/quote Any reason not to use the pc? Speed of 3? Quote Link to comment Share on other sites More sharing options...
0 mc2hill Posted October 17, 2010 Share Posted October 17, 2010 Any reason not to use the pc? Speed of 3? No, it does help make the application thin and uniform. Speed from 2 to 3 works fine. Quote Link to comment Share on other sites More sharing options...
0 The Ryan Posted October 17, 2010 Share Posted October 17, 2010 Use the Americana applicator or the Red or Yellow Hex applicators.If you use a PC you can use the Grey pad as well. Quote Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted October 17, 2010 Share Posted October 17, 2010 Use the Americana applicator or the Red or Yellow Hex applicators.If you use a PC you can use the Grey pad as well.[/quote Any reason not to use the pc? Speed of 3? No reason, go for it!! Quote Link to comment Share on other sites More sharing options...
0 thedak Posted October 18, 2010 Share Posted October 18, 2010 Yellow Hex Pad works great for me. Quote Link to comment Share on other sites More sharing options...
0 Team Adam's Posted October 18, 2010 Share Posted October 18, 2010 A few reasons I like the Americana app better for hand application: 1) just like with waxes the foam apps apply much more evenly, b/c you're grip and the applicator surface are isolated somewhat from one another, the face stays flat against the surface. This gives you a much more even, thin, coat. Easier for removal - and on dark colors uneven application can sometimes manifest into an uneven looking color. Microfiber apps are great, but they tend to bunch up when you grip them and the products isn't applied as evenly. 2) Product soaks in very easily into both apps, but with the foam you can squeeze it back to the surface pretty easily. With the MF its pretty much lost once it soaks into the core. Not a big deal, but it will cause you to burn thru product faster. Quote Link to comment Share on other sites More sharing options...
TR6speed
10 answers to this question
