I know this system is set up very easy to use! I watched Junkman's video to express how easy it was...... in his words "Dude its that easy" haha!
My question is one that I am sure has been asked! While looking for that perfect finish, how do you determine if an lighter pad can be used for a smaller cut, Should I stick with the method of using DS to prime the pad therefore reducing its cutting power.
For instance, When would it be nessecary to use the SHR on the white pad?
Would i be correct to assume that on a older car you would use this technique to cut less, (cause less damage)? I have many friends here locally that have older cars that have been treated to a show car paint job but aren't taken care of like they should be! I want to risk the least possible amount, and only work as little as possible on the surfaces that have very small swirls!
LowNslo
thanks,
Chris
11 answers to this question
