i used my Porter Cable 7424XP for the first time and it turn out it was not that easy as i thought ! , it was hard the first panel i did which was the fender
it has alot of curves
as you can see the amount of swirls and scratches that i have >.>
i managed to get like 98% of swirls and scratches off , but there is some that i cant take even after 5 passes.
i couldnt take photos of the left overs , but i will try to take another photo later on
my problem is i cant get some scratches off at all using SHR and orange pad , with over 5 passes , my hands/arms are vibrating even with out using the PC >.>
this is my hood , i wanted to test on a small area
its my DD , so it has swirls that will show on some light and angles
on the hood i managed to get the scratches on photos , there is some more on the fender and the hood
the scratches are fine , not that deep and barely can feel them with my finger nails
my question is should i move to the yellow pad ? or should i use speed 6 on the PC with orange pad with more pressure?
nawal
23 answers to this question
