Team Adam's Posted November 12, 2010 Share Posted November 12, 2010 (edited) Edited April 4, 2012 by Dylan@Adams Link to comment Share on other sites More sharing options...
0 Team Adam's Posted November 12, 2010 Author Share Posted November 12, 2010 Spreading a product like MSW with a machine like the flex doesn't work well. You end up with a problem similar to if you attempted to apply it by hand. Highs, lows, uneven and blotchy application. The end result is often uneven and difficult to remove with a muddied appearance. The rotation of the head is what causes the problems. With the PC on 3 its not even trying to spin so you can apply a product. The Flex is purely a POLISHER, not suited for application. We're not going to be offering a gray flat pad either, simply don't want people to assume it will work as well as it does with the PC and be disappointed. Link to comment Share on other sites More sharing options...
0 XXFirefighter Posted November 13, 2010 Share Posted November 13, 2010 I'm even more confused now... I have a 09 G8 GXP. No CLUE on what one to get now... Seems like I almost NEED both... Link to comment Share on other sites More sharing options...
0 Team Adam's Posted November 13, 2010 Author Share Posted November 13, 2010 I'm even more confused now... I have a 09 G8 GXP. No CLUE on what one to get now... Seems like I almost NEED both... Whats confusing you and maybe I can help alleviate the issue. The principle thing to understand is that the flex is a more powerful tool, it will produce results much faster than the PC and achieve some things that the PC simply cannot like heavier paint restoration. The one shortcoming is we've found its not nearly as effective at applying sealants/waxes/glazes. Not saying it can't, but we just don't recommend it. Its not MUCH of a drawback when you consider it really only impacts one product (Machine Superwax) outside of that it can do all the things the PC does, in less time, and some things the PC can't. When you're done polishing you choose from one of our hand applied products (Americana or Buttery) to protect the finish. Link to comment Share on other sites More sharing options...
0 Kingsford Posted November 13, 2010 Share Posted November 13, 2010 I'm even more confused now... I have a 09 G8 GXP. No CLUE on what one to get now... Seems like I almost NEED both... I'd say if you are new to detailing.... Get a PC to start. Its fairly cheaper and you can learn a great amount of things by using it as a beginner, like I did. Link to comment Share on other sites More sharing options...
0 XXFirefighter Posted November 13, 2010 Share Posted November 13, 2010 I'd say if you are new to detailing.... Get a PC to start. Its fairly cheaper and you can learn a great amount of things by using it as a beginner, like I did. Sounds like the PC will be my first machine then. I'm a virgin. Thanks Link to comment Share on other sites More sharing options...
0 19stang88 Posted November 13, 2010 Share Posted November 13, 2010 Definitely recommend the Pc. especially for starters! after a year under your belt, like junkman says, upgrade to the pc Link to comment Share on other sites More sharing options...
0 Mick Posted November 13, 2010 Share Posted November 13, 2010 Just the other day my son said. Dad have not seen an Adams delivery in a while... That is about to change. Link to comment Share on other sites More sharing options...
0 mcss383 Posted November 13, 2010 Share Posted November 13, 2010 You might be interested in this thread: http://www.adamsforums.com/forums/showthread.php?t=9214 You are correct sir, I am very interested in that thread! Link to comment Share on other sites More sharing options...
0 Junkman2008 Posted November 13, 2010 Share Posted November 13, 2010 Definitely recommend the Pc. especially for starters! after a year under your belt, like junkman says, upgrade to the pc I would never put a time limit on when you should upgrade. For some people. they may only use their PC 4 times in a year. That would not be enough time to consider yourself experienced with the PC. You only upgrade if there is a need to do so and you are experienced enough with the PC to know when you should. The Flex is also not a necessary machine for everyone. If the paint on your cars is in the condition that the paint on mine is in, you would have no need for the Flex whatsoever. I can easily maintain my paint with the PC, which means that I am removing as little clear coat as necessary to do so. The key is that I properly maintain my paint and thus, I don't have to keep fixing it. Link to comment Share on other sites More sharing options...
0 Bunky Posted November 13, 2010 Share Posted November 13, 2010 (edited) I have found you do not need as aggressive polish/pad to get the same amount of paint leveling (removing clear) so someone upgrading from a PC to a Flex should not automatically use the same polish/pad combos. Start with a less aggressive method first to see what works so you are not removing unnecessary paint rather than just using prior PC combos. In the end to remove a swirl, you have to remove x amount of paint no matter which machine you use. I like the fact it can do it faster, less sensitive to down pressure (just hold it flat against the paint), but it does not work well in tight spots where a 4-in pad is needed. Edited November 13, 2010 by Bunky Link to comment Share on other sites More sharing options...
0 mc2hill Posted November 13, 2010 Share Posted November 13, 2010 I'd say if you are new to detailing.... Get a PC to start. Its fairly cheaper and you can learn a great amount of things by using it as a beginner, like I did. Well said Jason. Link to comment Share on other sites More sharing options...
0 Team Adam's Posted November 13, 2010 Author Share Posted November 13, 2010 I have found you do not need as aggressive polish/pad to get the same amount of paint leveling (removing clear) so someone upgrading from a PC to a Flex should not automatically use the same polish/pad combos. Start with a less aggressive method first to see what works so you are not removing unnecessary paint rather than just using prior PC combos. In the end to remove a swirl, you have to remove x amount of paint no matter which machine you use. Excellent Point Al! Link to comment Share on other sites More sharing options...
0 nawal Posted November 14, 2010 Share Posted November 14, 2010 will there be a 220v version for the flex ? Link to comment Share on other sites More sharing options...
0 mc2hill Posted November 14, 2010 Share Posted November 14, 2010 will there be a 220v version for the flex ? There is a 220v version available, but I would doubt it would be carried in the online store. Link to comment Share on other sites More sharing options...
0 Junkman2008 Posted November 14, 2010 Share Posted November 14, 2010 will there be a 220v version for the flex ? You need to check with UK retailers to get that one. I don't know if the model numbers and name is the same though. For example, the PC is called the DAS-6 over seas. Link to comment Share on other sites More sharing options...
0 Team Adam's Posted November 14, 2010 Author Share Posted November 14, 2010 Listen to the Junkman.... I'm sure we could get you in touch with someone to get you the 220v version, but ours are shipping from the US distribution hub and they won't have any. Link to comment Share on other sites More sharing options...
0 DasSmurf Posted November 15, 2010 Share Posted November 15, 2010 That just took all the guess work out of my decision making! Since I've yet to use a machine, PC it is. Awesome writeup. Very glad I found this. Link to comment Share on other sites More sharing options...
0 Junkman2008 Posted November 15, 2010 Share Posted November 15, 2010 That just took all the guess work out of my decision making! Since I've yet to use a machine, PC it is.Awesome writeup. Very glad I found this. You definitely want to start with the PC. Definitely. Link to comment Share on other sites More sharing options...
0 Kingsford Posted November 15, 2010 Share Posted November 15, 2010 ours are shipping from the US distribution hub and they won't have any. Does this mean we will get our Flex's straight from the factory and the pads from Adam's or is Adam's shipping everything? Link to comment Share on other sites More sharing options...
0 Team Adam's Posted November 15, 2010 Author Share Posted November 15, 2010 Does this mean we will get our Flex's straight from the factory and the pads from Adam's or is Adam's shipping everything? Nope... shipping from us, but our shipments come from Flex US dist. facility. Link to comment Share on other sites More sharing options...
0 Chewy Posted November 15, 2010 Share Posted November 15, 2010 You definitely want to start with the PC. Definitely. I would agree with this statement. These guys make it look easy in their videos. I have yet to use a Flex (soon) but I have used a rotary and they are more of a handful so I see this being a bit more work to use. I have thought about getting a hood and trunk off a beater at the junkyard and testing it on that first. I may just use my wifes Enclave instead... lol Link to comment Share on other sites More sharing options...
0 Kingsford Posted November 15, 2010 Share Posted November 15, 2010 Nope... shipping from us, but our shipments come from Flex US dist. facility. Good deal! I love the boys and girls who pack for Adam's everything is always so neatly placed! Link to comment Share on other sites More sharing options...
0 Foxxer Posted November 21, 2010 Share Posted November 21, 2010 This is so helpful! Thanks Dylan. Link to comment Share on other sites More sharing options...
0 VertimgoC502 Posted November 26, 2010 Share Posted November 26, 2010 So as I understand it; the yellow pad and SHR are replaced by the green pad and SSR for the Porter Cable? So it is now green/SSR, Orange/SHR, White/FMP, and Gray/SMW? Link to comment Share on other sites More sharing options...
0 mc2hill Posted November 26, 2010 Share Posted November 26, 2010 So as I understand it; the yellow pad and SHR are replaced by the green pad and SSR for the Porter Cable? So it is now green/SSR, Orange/SHR, White/FMP, and Gray/SMW? You got it! Link to comment Share on other sites More sharing options...
Team Adam's
Top Posters For This Question
17
11
11
8
Popular Days
Nov 12
27
May 11
12
Nov 13
11
May 12
11
Team Adam's 17 posts
Junkman2008 11 posts
mc2hill 11 posts
Chewy 8 posts
Popular Days
Nov 12 2010
May 11 2011
Nov 13 2010
May 12 2011
115 answers to this question
