Ian6 Posted November 22, 2010 Share Posted November 22, 2010 The clear is bubbling on the factory aluminum clear coated rims on my K5 Blazer I just bought. what chemical should I use to remove the clear. and after the clear is removed I should polish with MP and a powerball right? Quote Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted November 22, 2010 Share Posted November 22, 2010 I read a article about this a while back, but I forget how they did it. Try to google it. Sorry! Quote Link to comment Share on other sites More sharing options...
0 GTO Guy Posted November 22, 2010 Share Posted November 22, 2010 would airplane stripper work? Quote Link to comment Share on other sites More sharing options...
0 Ian6 Posted November 22, 2010 Author Share Posted November 22, 2010 would airplane stripper work? thats what I've read, just wanted to know if anyone on here has done it before and had any tips Quote Link to comment Share on other sites More sharing options...
0 GTO Guy Posted November 22, 2010 Share Posted November 22, 2010 thats what I've read, just wanted to know if anyone on here has done it before and had any tips i would do that or media blast Quote Link to comment Share on other sites More sharing options...
0 Kingsford Posted November 22, 2010 Share Posted November 22, 2010 Media blast might be better. I figure its best to avoid harsh chemicals. Quote Link to comment Share on other sites More sharing options...
0 whiterp199 Posted November 22, 2010 Share Posted November 22, 2010 I would go with media blasting. Walnut shells should remove the clear without damaging the aluminum underneath. Quote Link to comment Share on other sites More sharing options...
0 Ian6 Posted November 22, 2010 Author Share Posted November 22, 2010 how much do you think that would cost for 4 15" rims? Quote Link to comment Share on other sites More sharing options...
0 butchman Posted November 22, 2010 Share Posted November 22, 2010 I recently tackled a project like this. I bought a used set of rims are off a 84 Grand National. I started with 320 grit, then 600, then 1000. You could even go 1500 grit if needed. Finally I used Adams Metal polish. It was actually pretty easy. I cleaned another set of similiar rims with just the metal polish. It worked but took forever. The sandpaper gets rid of the oxidation pretty quick. Quote Link to comment Share on other sites More sharing options...
0 Ian6 Posted November 22, 2010 Author Share Posted November 22, 2010 those came out awesome, did you wet or dry sand? Quote Link to comment Share on other sites More sharing options...
0 Kingsford Posted November 22, 2010 Share Posted November 22, 2010 how much do you think that would cost for 4 15" rims? Depending what brand... $500-1500. Plus new tires if you need them. Quote Link to comment Share on other sites More sharing options...
0 whiterp199 Posted November 23, 2010 Share Posted November 23, 2010 I media blast my self. If you already have an air compressor you can get the whole set up for about 100 dollars, I do not imagine it would cost much more then that too have four 15 inch wheels blasted either. There is no way you would spend 500 to 1500 to have four wheels media blasted. Quote Link to comment Share on other sites More sharing options...
0 Ian6 Posted November 23, 2010 Author Share Posted November 23, 2010 I'm going to see how much effort sanding and chemical stripper take on one wheel, then see if its worth the cash. Quote Link to comment Share on other sites More sharing options...
0 butchman Posted November 23, 2010 Share Posted November 23, 2010 (edited) those came out awesome, did you wet or dry sand? Thanks. I dry sanded them with 3M wet or dry sandpaper. This is the first time I've done a project like this. I was going to get them blasted and figured I would give it a try. It was much easier than I thought. Only sanding expertise I had was with woodworking. BTW when I was researching the pricing I found was anywhere from $25-$50 per wheel to get them soda blasted. Edited November 23, 2010 by butchman Quote Link to comment Share on other sites More sharing options...
0 Ian6 Posted November 23, 2010 Author Share Posted November 23, 2010 so yours were clear coated too right? Quote Link to comment Share on other sites More sharing options...
0 butchman Posted November 23, 2010 Share Posted November 23, 2010 so yours were clear coated too right? Yep. I believe the clear wears off and thats when the aluminum oxidizes. Quote Link to comment Share on other sites More sharing options...
0 whiterp199 Posted November 23, 2010 Share Posted November 23, 2010 Yep. I believe the clear wears off and thats when the aluminum oxidizes. That is the way I normally see it occur. I would say try some 3m aircraft stripper. It should take the clear off. I am not sure if it has any ill effects on aluminum though. Quote Link to comment Share on other sites More sharing options...
0 butchman Posted November 23, 2010 Share Posted November 23, 2010 I was afraid to mess with the chemicals. I've heard that works pretty good though. Quote Link to comment Share on other sites More sharing options...
0 02Xtreme07ss Posted November 23, 2010 Share Posted November 23, 2010 Guys on the TBSSOwners site have used aircraft stripper to remove their factory clear without issue. You'll end up doing a lot of polishing once you get the clear off, but it will be worth it. You also might want to look into having the wheels re-cleared after you have them polished the way you want, otherwise you should plan on polishing all the time as that bare aluminum will constantly require attention and especially if you live in a part of the country where salt or sodium chloride are used during the winter months on the roads. Quote Link to comment Share on other sites More sharing options...
0 Ian6 Posted November 23, 2010 Author Share Posted November 23, 2010 Guys on the TBSSOwners site have used aircraft stripper to remove their factory clear without issue. You'll end up doing a lot of polishing once you get the clear off, but it will be worth it. You also might want to look into having the wheels re-cleared after you have them polished the way you want, otherwise you should plan on polishing all the time as that bare aluminum will constantly require attention and especially if you live in a part of the country where salt or sodium chloride are used during the winter months on the roads. I've heard that all chemical strippers are basically the same only some are stronger like the aircraft stripper and I have two gallons of jasco stripper which I read has almost the same chemical ingredients as the aircraft stripper and I've read some people have used jasco so I'll give that a try. Yeah I might re-clear them at school next year but I dont have to worry about them getting messed up in the winter, I live in Texas so there is no such thing as salt on the road maybe a little sprinkle of sand on the one day during winter that we might see some ice but on that day I dont even leave the house unless someone picks me up lol not worth the risk of accident Quote Link to comment Share on other sites More sharing options...
0 Kingsford Posted November 23, 2010 Share Posted November 23, 2010 I media blast my self. If you already have an air compressor you can get the whole set up for about 100 dollars, I do not imagine it would cost much more then that too have four 15 inch wheels blasted either. There is no way you would spend 500 to 1500 to have four wheels media blasted. I misread what he typed. I thought he asked how much new rims would cost. Quote Link to comment Share on other sites More sharing options...
0 Ian6 Posted November 23, 2010 Author Share Posted November 23, 2010 its all good man Quote Link to comment Share on other sites More sharing options...
0 butchman Posted November 23, 2010 Share Posted November 23, 2010 Guys on the TBSSOwners site have used aircraft stripper to remove their factory clear without issue. You'll end up doing a lot of polishing once you get the clear off, but it will be worth it. You also might want to look into having the wheels re-cleared after you have them polished the way you want, otherwise you should plan on polishing all the time as that bare aluminum will constantly require attention and especially if you live in a part of the country where salt or sodium chloride are used during the winter months on the roads. I was originally going to leave mine raw like in the pictures. My friends said the same thing you did. I painted the black part with Duplicolor wheel paint satin black, then I painted the entire rim with Duplicolor wheel paint clear. It only took a can and a half for all 4 rims. Now I just have to see how it holds up. Its a summer car so should be too bad. Quote Link to comment Share on other sites More sharing options...
0 Z71_Denali Posted November 23, 2010 Share Posted November 23, 2010 (edited) i think you should dry sand them starting with 320, 600, then 1000 then wet sand them with 2000, 2500, then 3000 grit then fine steel wool then SSR or SHR apply by hand for a brushed look, or with a focal pad and powerball for a mirrored look. then MP by hand, focal pad, or powerball just like you did with the SSR or SHR then your choice of wax by hand and you will have some brand spankin' new looking wheels! estimated time and cost: 1 hour per wheel, $50 in materials. some tips: stop dry sanding once you know you've gotten through the clear coat. with each step after that, the scratches/swirls should get finer and finer. once you get to the polishes, don't stop until you cannot see anymore scratches or swirls, unless your going for that brushed look. a couple coats of wax should seal them up nice! Edited November 23, 2010 by 2010TexasEdition Quote Link to comment Share on other sites More sharing options...
0 Ian6 Posted December 2, 2010 Author Share Posted December 2, 2010 I decided to use the stripper because the wheels are brushed aluminum and I thought that I'd end up messing up the metal if I sanded it because getting the clear out of the tiny grooves would require sanding down to that level [i guess its called brushed aluminum, makes a record scratch sound like a DJ when I rub my nail on it lol] Used Jasco sealant and adhesive stripper/remover, applied with trim paintbrush so as to not get it on the tires, waited for the clear to start bubbling then scraped it off with a plastic scraper and blasted the rest of the softened clear off with the hose pressure nozzle. cleaned up my DRL's/indicator lights while I was at it too Before After Before After the clear was stripped off After metal polish Still need to hit some spots with a more aggressive polish, what would you guys recommend, wish adams made one [but I do understand that a product like that wouldnt sell well since most adams customers wouldnt need it] SO what metal polish, product, or method would you guys recommend on the more stubborn spots, Thanks Quote Link to comment Share on other sites More sharing options...
0 RyGo Posted December 2, 2010 Share Posted December 2, 2010 I have no experience first hand, but in the past I've heard of people using Billet Polish of some sort with flour (yes cooking flour) as a cutter with either machine or hand application to polish aluminum wheels. Quote Link to comment Share on other sites More sharing options...
Ian6
25 answers to this question
