Precision machined from a solid chunk of high quality 6061 T6 aluminum, then hard coated for corrosion resistance the Adam's Ultimate Fire Hose Nozzle will blow you away as its high pressure spray patterns blow dirt and soap effortlessly from your finish.
Featuring a flow rate of over 5 gallons per minute at just 40psi this is one powerful nozzle when you need it to be, but the spray can be adjusted to a wide fan for more delicate use. In a tight stream the pressure generated completely outpaces anything offered by our competitors, and with the solid aluminum construction and sidewalls 3/8" thick it will withstand years of use without ever getting bent, cracked, or damaged. This very well may be the last fire hose nozzle you ever buy!
The massive rubberized bumper and precision machined crosshatch milling makes sure it won't slip from your grip when things get soapy. We 110% guarantee that this nozzle will impress you just as much as it impresses us!!
SHUT-OFF VALVE
Sometimes its just about having the little things to make life easier, this is one of those things. If you're washing your car using a 50ft hose chances are the shut off is a good distance from where you're working. Adding a high quality shut-off valve to the end of the hose will allow you to control the water from where you're at, not where it starts!
Switching from one hose attachment to another? Simply flip the valve to off, swap attachments, and proceed without having to go anywhere.
Done hosing the car off? Conserve water and shut the flow off while you soap up the paint.
Don't want to search for the perfect setting on your fire hose nozzle each time? Use the valve to shut the water off instead of the twist action of the nozzle, that way each time you turn the valve on, the nozzle is set exactly how you want it!
100% high quality brass construction and made here, right in the USA, this is the alternative to the cheap, imported plastic shut off valves, sold at the big chain stores. 110% guaranteed to be the highest quality shut off valve you'll ever use!
Team Adam's 4,883
Fire Hose Nozzle - $49.95
Shut Off Valve - $19.95
Or Get Both for Just - $64.95
BOTH UNITS ARE 100% MADE IN THE USA!!
ADAM'S ULTIMATE FIRE HOSE NOZZLE
SHUT-OFF VALVE
Edited by Dylan@AdamsLink to post
Top Posters For This Question
7
5
4
4
Popular Days
Dec 13
15
Jan 6
9
Jan 7
7
Dec 16
6
Team Adam's 7 posts
The Ryan 5 posts
Chris@Adams 4 posts
rwisejr 4 posts
Popular Days
Dec 13 2010
Jan 6 2011
Jan 7 2011
Dec 16 2010
Posted Images
61 answers to this question
