mike6187 Posted June 11, 2011 Share Posted June 11, 2011 (edited) Hi guys! need some help here. Droning noise has been steadily getting worse for 2 to 3 weeks. A friend of mine who came for a ride in the car seems sure it's due to a worn wheel bearings or a bad wheel bearing module... does anyone here experience the same thing too? Edited June 14, 2011 by mike6187 Quote Link to comment Share on other sites More sharing options...
0 Redvenm Posted June 11, 2011 Share Posted June 11, 2011 How about some background on your car. What make and model and year? How many miles are on it? How long have you had it for? Etc Etc. Quote Link to comment Share on other sites More sharing options...
0 BrianT Posted June 11, 2011 Share Posted June 11, 2011 You need to get the car in the air and see if you can feel which wheel hub is bad. If it's getting worse than it should not be that hard to find the bad on. You can do this with a jack, but I would recomend getting both fronts off the ground so you can compare both sides at the same time! Quote Link to comment Share on other sites More sharing options...
0 mike6187 Posted June 14, 2011 Author Share Posted June 14, 2011 (edited) Thanks for the quick response guys... Going to get my car to a shop since my work is killing my time and can no longer fix it myself. i'll just keep you posted for the result. Edited June 15, 2011 by mike6187 Quote Link to comment Share on other sites More sharing options...
0 blackws6ta Posted June 16, 2011 Share Posted June 16, 2011 Alot of times with the wheels off the ground you may not be able to feel or see movement in the wheel. If it's Front Wheel Drive you can start it in the air and put it in drive and let it idle. Always make sure it is seated on stands securely and a jack is under it as a secondary safety. While it's idling put your hand on the strut or upper control arm and feel for a vibration. This is what we do at my shop if we don't want to bring out the chassis ear. Good luck! And be safe! Sent from my DROIDX using Tapatalk Quote Link to comment Share on other sites More sharing options...
mike6187
Edited by mike6187Link to comment
4 answers to this question
