CMorg Posted June 18, 2011 Share Posted June 18, 2011 I cannot for the life of me get my air vents looking perfect. I dont know what to use. I tried Q Tips and got alot out. What else should I use ? Link to comment Share on other sites More sharing options...
0 Kustom_FX Posted June 18, 2011 Share Posted June 18, 2011 I went to the DIY store and bought a couple different diameter dowel rods. Then I cut up one of my VRT Super Block Dressing Applicator and super glued them on the ends. I use them in the engine, interior, door jambs. Wherever I need a little extra length and or a tight space. Im at work I would post some pics... Hope this helps. Link to comment Share on other sites More sharing options...
0 CMorg Posted June 18, 2011 Author Share Posted June 18, 2011 Thats a great Idea. I think I have some dowel rods here. I have some foam , but its not Adams , it is just something that came in a shipment I got , looks like the same stuff , but it was used as packaging ? Link to comment Share on other sites More sharing options...
0 BlueGenCoupe Posted June 18, 2011 Share Posted June 18, 2011 I went to the DIY store and bought a couple different diameter dowel rods. Then I cut up one of my VRT Super Block Dressing Applicator and super glued them on the ends. I use them in the engine, interior, door jambs. Wherever I need a little extra length and or a tight space. Im at work I would post some pics... Hope this helps. Sounds good, but I need some visualization:jester: Post some pics Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted June 18, 2011 Share Posted June 18, 2011 Try this!!:thumbsup: Adam's In & Out Spray Dressing <!-- Footer --> Link to comment Share on other sites More sharing options...
0 krewsman Posted June 18, 2011 Share Posted June 18, 2011 :iagree: Link to comment Share on other sites More sharing options...
0 crowvet Posted June 19, 2011 Share Posted June 19, 2011 :iagree: :iagree: Link to comment Share on other sites More sharing options...
0 GXPaycheck Posted June 19, 2011 Share Posted June 19, 2011 http://www.adamsforums.com/forums/showthread.php?t=12272 Link to comment Share on other sites More sharing options...
0 Robert Posted June 19, 2011 Share Posted June 19, 2011 http://www.adamsforums.com/forums/showthread.php?t=12272 I use the same, very cheap for a mixed bag at Home Depot. Link to comment Share on other sites More sharing options...
0 RedexInLA Posted June 20, 2011 Share Posted June 20, 2011 No need to dress it until it's clean. A small foam paint brush works well, I tried it, saw a tip here. Link to comment Share on other sites More sharing options...
0 Team Adam's Posted June 21, 2011 Share Posted June 21, 2011 the lug nut brush can also be used for this... just use it dry. Link to comment Share on other sites More sharing options...
0 StoneGrinder Posted June 21, 2011 Share Posted June 21, 2011 Clint, If you are talking about 'cleaning' your air vents, the lug nut brush should work well. If you need something smaller or stiffer, I might suggest a 1" or even 1/2" chip brush from a hardware store. If you cut the bristles down, you can get pretty aggressive with them. And you won't have to chop up a good Adam's brush . You might want to put a wrap of tape over the metal on the brush, some have sharp edges that you won't want near your dash. If a brush alone won't get you there, try some Interior Cleaner. Just make sure you have a towel handy to catch the potential drips. When you are all finished, turn the fan on high to help blow any excess out but cover the vents with a towel so you don't blow it all over your freshly detailed interior. Link to comment Share on other sites More sharing options...
CMorg
11 answers to this question
