musclejunkie Posted June 28, 2011 Share Posted June 28, 2011 I am going to attempt my first engine compartment detailing on the '11 Mustang. What are the do's and don'ts as far as what areas to protect with a baggie and not get wet? I'm going to use 50/50 APC and Boars Hair brush. Thanks amigos. Link to comment Share on other sites More sharing options...
Team Adam's Posted June 28, 2011 Share Posted June 28, 2011 Do NOT use the aluminum foil on a battery. I know that sounds like a stupid thing to say, but there are people out there that would do it!!!! I don't blow dry my engines for fear of driving water somewhere, but if you're careful around the engine area, it'd work great. LOL... yea, sorry... should have worded that better. Link to comment Share on other sites More sharing options...
Chris@Adams Posted June 28, 2011 Share Posted June 28, 2011 Do NOT use the aluminum foil on a battery. I know that sounds like a stupid thing to say, but there are people out there that would do it!!!! I don't blow dry my engines for fear of driving water somewhere, but if you're careful around the engine area, it'd work great. I always dry with the Master Blaster, so far never a problem! Link to comment Share on other sites More sharing options...
Chewy Posted June 28, 2011 Share Posted June 28, 2011 Do NOT use the aluminum foil on a battery. I know that sounds like a stupid thing to say, but there are people out there that would do it!!!! I don't blow dry my engines for fear of driving water somewhere, but if you're careful around the engine area, it'd work great. Link to comment Share on other sites More sharing options...
Team Adam's Posted June 28, 2011 Share Posted June 28, 2011 Just don't use high pressure and your fine. A little aluminum foil or plastic bags to cover open element filters, battery terminals, or other things that might be sensitive to water and you're good to go. Modern engine bays really aren't all that susceptible to water related issues. <iframe width="853" height="510" src="http://www.youtube.com/embed/JdHX_wPUKZI?rel=0" frameborder="0" allowfullscreen></iframe> Link to comment Share on other sites More sharing options...
Chris@Adams Posted June 28, 2011 Share Posted June 28, 2011 If its just dusty cover up areas like Christopher said, hose off & blow dry with air (I use my Master Blaster) then all you may need is DS.I f the DS don't get it then I would use APC. After wiping down with DS go over with SVRT and In & Out Spray! Link to comment Share on other sites More sharing options...
musclejunkie Posted June 28, 2011 Author Share Posted June 28, 2011 It isn't too bad - just mostly road dust. Maybe the blaster would be a better alternative? In Adam's video #6 he says the new cars aren't as bad as the older cars. I'm just a little paranoid about spraying water around in the engine compartment. I also know enough not to spray a hot engine. Link to comment Share on other sites More sharing options...
Chewy Posted June 28, 2011 Share Posted June 28, 2011 Don't spray water directly at and under pressure at electronic components. If you have an open element air filter then cover it. How dirty is it? I use a spray bottle of car shampoo and water to clean mine. If they're greasy, then APC is great! I did my P/U truck and covered nothing. Link to comment Share on other sites More sharing options...
musclejunkie
32 answers to this question
