I am working on trying to get out some wter etchings on the hood of my car. I don't know if you'd actually call them etchings or not, since there are not craters formed in the paint just outlines on the clear finish where the water and dirt sat. My car is driven daily and sits outside 24/7 at the moment, but I do bust my butt on it all the time and put lots of hours into it to make it look its best. The last time it was washed was a couple weeks ago, and during that time it has been driven and sat through stroms and days in high 90 degree heat. Whenever it did rain the sun did not come out after to heat it in quicker. The car did have dried on water that looked dirty for a week or so, but I didn't think much of it becuase I have never had a problem with this before and figured that they'd wash off. I'd have never though this was going to happen, otherwise I'd have taken the chance using a waterless wash to get the dirt off of it.
Anyways, after washing I tried the easiest stuff first, vinegar, non abrasive cleaner polish, and nothing there. So I went ahead and got the PC 7424 out and used some Danase Swirl Abolisher II and I with 6.5" Lake Country CCS orange and white pads. I don't really know how these polishes compare to others out there since its all I have ever used, plus it's not really a widely used polish, so I can't comment. I thought I had them all out with this combination, since a few IPA wipeedowns showed nothing, so I threw some wax on. This took care of maybe 20% or so of them, but they then reappeared since later on. I guess the polish was just masking them from the oils in it I guess. Since the oils left from polish was just masking them, does this seem like they can be still corrected with a PC without having to resort to drastic measures such as wet sanding?
I have never used the Adams Products before, but I have heard lots of positives on them and have become interested in trying them. I am thinking that I may need to try the Severe Swirl Polish Remover with these, or at least try the Swirl & Haze Remover Polish (Any suggestions on what to try next?). I see that the polishes that Adams offers also has color coded pads to use with them. I have the older style Porter Cable 7424, the non XP version, and I know that if you start to put a real good amount of pressure down with 6.5" pads that the pad will actually stop rotating. Are the Adams pads reccomended for use on the older style 7424s, or should I use a different style pad or a smaller one? I know that the XPs have a little more power, so I am wondering if the older models will have enough power to spin the pad and correct as intended without bogging down.
Also, do you all have any before and after pics, testimonials, or anything else that can show the capabilites of the Severe Swirl Polish Remover and the Adams green pads? Thanks for any help
05RLS2
8 answers to this question
