doweigyman Posted July 17, 2011 Posted July 17, 2011 I take my dog out so he can do his business and I'm walk beside my truck and I see all these marks showing up. What did i do wrong!!! :confused:
Redvenm Posted July 17, 2011 Posted July 17, 2011 Hard to say bro. How about some more info. What did you do? wash? how did you dry? did it rain? sprinklers? clay? Lets start with more info, the more you can provide the easier it is to figure it out?
doweigyman Posted July 17, 2011 Author Posted July 17, 2011 opps my bad bro. I wasn't even thinking about that LOL. Rinse foam gun 2 bucket wash rinse sheet died leaf blower dired remaining water clay & DS washed again Started with FMP, work the probuct, then wiped it off with single soft microfiber towel. Did a second pass same way. It still had some swirls so i did SHR, Work that, then wipe it off. Then another pass with FMP follow by MSS. Wpied it with single soft microfiber towel. when i finish it started pouring rain like 10 mins later.
Redvenm Posted July 17, 2011 Posted July 17, 2011 It is hard to tell from the pics. Does that wipe off with DS?
doweigyman Posted July 17, 2011 Author Posted July 17, 2011 It is hard to tell from the pics. Does that wipe off with DS? Nope !! Thanks for your help bro ! I appreciate you!
bjoeaull Posted July 17, 2011 Posted July 17, 2011 tough, call, without seeing it in person. Does it wipe off? Is it all over or just the bed part. If so did you put a product on the bed top and it ran off in the rain?
doweigyman Posted July 17, 2011 Author Posted July 17, 2011 tough, call, without seeing it in person. Does it wipe off? Is it all over or just the bed part. If so did you put a product on the bed top and it ran off in the rain? Noppers it won't wipe off and I havent put anything on bed top. Oh and it's down the sides. I don't see it on the hood or top of the cab.
doweigyman Posted July 17, 2011 Author Posted July 17, 2011 Could it be holograms? I only did 9-14 lbs of pressure with my PC.
Team Adam's Posted July 17, 2011 Posted July 17, 2011 It is IMPOSSIBLE to introduce holograms with the PC. that looks to be residual product that didn't get removed fully, which is understandable since it was starting to rain when you finished. You probably just didn't get it all off. Clean the area with a little isopropyl alcohol and a plush towel, then reapply your MSS.
InDepthAutoDetailing Posted July 17, 2011 Posted July 17, 2011 I could be wrong but I don't think it's any chance of it being holograms. Is it possible it was there after the FMP and you didn't notice? Ive had a few occasions of where I overworked the FMP and the only way to fix it was to go over it again. Other possibility, is there anything above the area you would have applied SVRT? I have areas below my mirrors where it ran after a rain because I applied it too heavy. If you wanna make the drive up I'd be happy to help.
JunkmansHomeboy Posted July 17, 2011 Posted July 17, 2011 I had something like that on my old ride. Turned out to be left over product. Maybe yours is the same.
Chris@Adams Posted July 17, 2011 Posted July 17, 2011 I am sure you will find that its left over residue!
1anonly Posted July 17, 2011 Posted July 17, 2011 It's one of two things. FMP or MSS. My guess is that you didn't completely wipe the FMP off. FMP is greasy and would do that. I have had the same thing in the past. How clean was your towel when you were wiping it off? When wiping off polish, make sure you keep folding the towel to a clean side. Do what Dylan said and you should be good.
Vincenzo Posted July 18, 2011 Posted July 18, 2011 I definitely sounds like you either didn't wipe the FMP off all the way or you didn't get all the MSW off. You should strip it and re-wax it.
doweigyman
13 answers to this question
