I'm trying out my Porter Cable for the first time and I'm using the SHR and orange pad. I hit this first test area of my hood 3 times so far and I'm still left with these scratches. You can't feel them with your fingernail and I figured machine polishing would cut right through them. I initially used speed 5, but I have used speed 6 the last two hits because I wasn't seeing results.
Am I going to need to wet sand with 2500 and then 3000 before moving to the SHR? I don't have the SSHR and would rather just jump right to the wet sanding instead of trying SSHR and the green pad only to find out it's equally as ineffective.
Also, my polish seems to flash faster than I expected. I go horizontally over an area and then vertically over it and the polish is already clear. Am I doing something wrong?
chrisguga
Thanks for the help,
Chris
36 answers to this question
