BETOGTI Posted August 1, 2011 Share Posted August 1, 2011 Hi guys, is there anything I can use on my Yamaha´s 2010 R1 windscreen to reduce the scratches? It is a clear stock windscreen. I was thinking of claying then SHR, FMP and MSW. Will this do the trick or these products are not recommended for this type of plastic? Thanks guys. Link to comment Share on other sites More sharing options...
Chris@Adams Posted August 1, 2011 Share Posted August 1, 2011 I would start with FMP & White pad first! Good luck!! Link to comment Share on other sites More sharing options...
BrianT Posted August 1, 2011 Share Posted August 1, 2011 Link to comment Share on other sites More sharing options...
1anonly Posted August 2, 2011 Share Posted August 2, 2011 If you use the 4" pads on a drill, becareful. Those windscreens are sometimes made from a softer plastic. If you put too much heat to them you could permantly haze them. I would use a PC or do it by hand. Link to comment Share on other sites More sharing options...
J Tegeler Posted August 1, 2011 Share Posted August 1, 2011 I used SHR on the hex grip on my R6 dark smoke windscrean, could see a good differnce right away, then hit it with some BG and it looked like new and shiny. Link to comment Share on other sites More sharing options...
pjwoolw Posted August 2, 2011 Share Posted August 2, 2011 I was thinking about this the other day. Thanks for bringing it up! Link to comment Share on other sites More sharing options...
BETOGTI Posted August 1, 2011 Author Share Posted August 1, 2011 Thanks, will give it a go today and post results later. Link to comment Share on other sites More sharing options...
BETOGTI Posted August 2, 2011 Author Share Posted August 2, 2011 Thanks guys, I delayed this a bit because decided to send bike to the shop to fix the cct problem (common to many 09-10 R1s) and will get on it as soon as it arrives back. Will keep you infomred. And yes I will do it with the PC and not the Drill, think it is safer this way. Thansks ! Link to comment Share on other sites More sharing options...
kdii02 Posted August 1, 2011 Share Posted August 1, 2011 I used SHR,FMP, and BG and my 4" pads on my PC to restore my Harley Windscreen. it worked wonders. I would definitely use the same process on my Ninja with no question. Link to comment Share on other sites More sharing options...
BETOGTI
Hi guys,
Thanks guys.
8 answers to this question
