well, after a few weeks i FINALLY got my technique down using the junkman's (3 pea size drops, 9-13lbs of pressure) and i got excellent results with the big orange pad . on the flip side, when using the 4 inch orange pad (on the pc) with SHR im not getting the same results.
ive watched all the vids and im not sure if there is a special trick to it that im missing. Initially i use 3 pea size drops of SHR and a mist of DS. after that i use 2 pea size drops of SHR (and of course DS) i've used both settings of 4 and 5, working in the polish well. Should i be using less than 9-13 lbs of pressure since it is a smaller/thinner pad? how do you guys do it using the PC with 4 inch pads?
JHL88
2 answers to this question
