csrt4 Posted September 3, 2011 Share Posted September 3, 2011 Hi, When I check the adam's video when I polish the car, between step 1,2 and 3, Adam's never wipe the residue between each step, why ? When I check other video on internet, the residue is wipe between each step ? There is a explanation that don't wipe residue between each step except to save time ? Thanks, Steve Link to comment Share on other sites More sharing options...
Chewy Posted September 3, 2011 Share Posted September 3, 2011 Correct! It's all about saving time and not dirtying polishing towels. Once you've figured out what it takes to correct YOUR paint by doing a 2x2 area and removing the polish to see your results, you don't have to remove as you go do the rest. Either way works, and if you're just starting out, it may be better to remove as you go, so you can make sure you're getting the results you want. Remember, always start with the least aggressive product and pad. If you need more, than switch up. Most correcting can be done with SHR and FMP. Chris Link to comment Share on other sites More sharing options...
csrt4 Posted September 3, 2011 Author Share Posted September 3, 2011 Correct! It's all about saving time and not dirtying polishing towels. Once you've figured out what it takes to correct YOUR paint by doing a 2x2 area and removing the polish to see your results, you don't have to remove as you go do the rest. Either way works, and if you're just starting out, it may be better to remove as you go, so you can make sure you're getting the results you want. Remember, always start with the least abrasive product and pad. If you need more, than switch up. Most correcting can be done with SHR and FMP. Chris Thank you for your fast answer. Link to comment Share on other sites More sharing options...
mc2hill Posted September 3, 2011 Share Posted September 3, 2011 Like Chris said, it's your choice. I usually work the 2x2 test area, then do the heavy polish on the entire car, wipe, then the lighter polish on the entire car and wipe. Link to comment Share on other sites More sharing options...
Bill-V8V Posted September 3, 2011 Share Posted September 3, 2011 I always clean between each step to check my progress, but not everyone does. Link to comment Share on other sites More sharing options...
Chris@Adams Posted September 3, 2011 Share Posted September 3, 2011 I always clean between each step to check my progress, but not everyone does. I do too, but it is a habit you really don't have to.And yes it is a time saver. Link to comment Share on other sites More sharing options...
csrt4
Thanks,
Steve
5 answers to this question
