Brilliant Glaze, which pad?
bobbagels
hello hello,
I been watching the videos and would like to ask a question,
After the swirl/haze remover, fine machine polish and sealer I would like to apply brilliant glaze then the Americana wax (i hope thats right)
Should I put the glaze on with hand applicator or use the PC (if pc what pad? my kit came with the gray pad not red)
12 answers to this question
If you aren't going to add a layer of MSS you can use the grey pad for the BG instead. It's easy on and easy off, so I would suggest doing it by hand if you have the option to use MSS.
A better bet would be to use the grey pad for MSS then the yellow applicator + BG followed by Americana on the red/blue applicator the next day.
hello hello,
For either application method use the wax pads. For machine, the gray pad is fine. By hand either the Buttery pad (yellow) or Americana (red). I prefer the yellow hex applicator with the black, firm hand grip, but others like the 'all soft' Americana one. You can also use a MF applicator!
I'm assuming the new Red pad would be what you would want to apply the Buttery with if you wanted to use a machine as well? Is there much difference in the cut of the Black and Red pads, bc I thought I had read a while back to use the Black pad for Buttery...obviously before the Red was introduced.
Dylan used the grey pad on his truck...
Didn't have time for claying so just threw down a coat of BG w/ the Flex on a Gen4 red pad, followed up with Buttery on a Gen4 gray pad. Figured I wouldn't waste Americana since I'm going to strip and really detail it this coming week.
But I would think either would work. Neither pad has any 'cut' which is the thing you don't want.
Correct... you could use either pad without issue... we offer both for a few reasons.
The red doesn't hold onto the thin glaze as well as the gray does, so you don't lose as much product into the pad. Not a huge issue, but I found thru testing and using the gray pad to glaze for some time now that the product soaks in, but doesn't come back out as easily so theres some excess lost. The red doesn't hold back much, so with just a little mash of pressure it squeezes back to the surface much better.
Secondly, having 2 colors gives you a visiual distinction so you don't have to guess (or smell) each pad to see what products have been used with it. The red pad will clearly be your glazing pad, your gray pad will clearly be your waxing or sealing pad.
