Griffinto Posted April 14, 2012 Posted April 14, 2012 Can machine polish be used on a clear Bra with the Flex? If so, which one? Thanks in advance!
THE Mook Posted April 15, 2012 Posted April 15, 2012 Yes, you want use be careful to watch the heat of the clear bra. FMP is the preferred polish. Speed 4-5. Watch the heat! Mook
dipolley Posted April 15, 2012 Posted April 15, 2012 Watch the edges of the clear bra as well. Tape of the very edge of the clear bra to make sure you don't catch the edge and potentially rip the bra. With the heat generation of the flex, this is especially important.
Team Adam's Posted April 15, 2012 Posted April 15, 2012 Agreed with both points above... nothing more aggressive than Fine Machine Polish and the white pad. Heavier abrasives can cause hazing on the material which can't be removed so stay with fine grade stuff and only polish it when needed, seal with Quick Sealant or your preferred wax.
BlueGenCoupe Posted April 15, 2012 Posted April 15, 2012 Agreed with both points above... nothing more aggressive than Fine Machine Polish and the white pad. Heavier abrasives can cause hazing on the material which can't be removed so stay with fine grade stuff and only polish it when needed, seal with Quick Sealant or your preferred wax. Dylan I've used SHR on my clear bra bc I was trying to remove a scuff mark and it didn't damage/haze at all. Use these products at your own risk..Im not saying they won't damage yours...
Innovative Detailing Posted April 16, 2012 Posted April 16, 2012 FMP with the Flex rotary using a combination of 6" and 4" focus pads worked fabulous for me. The case subject was a recent 2007 C6 Vert detail which had extremely oxidized PPF. I always recommend buffing "Cool" with PPF, heat is your enemy ....Once the inital correction has been made and the clarity and imperfections have been removed, then switch off to the Flex d/a using the same pads and FMP to finesse the PPF some more. A nice final application of Spray Sealant for your LSP and your done.....
PrinceValium Posted May 11, 2012 Posted May 11, 2012 The kneeling pad looks great! I was thinking about using knee pads this weekend. Where are those pads at?
Chewy Posted May 11, 2012 Posted May 11, 2012 The kneeling pad looks great! I was thinking about using knee pads this weekend. Where are those pads at? What are you talking about? Here's a great link to many threads on the subject. bra - Adam's Polishes Forums - Threads Tagged with bra I did a TAG search for "bra". Cheers
PrinceValium Posted May 11, 2012 Posted May 11, 2012 What are you talking about? Here's a great link to many threads on the subject. bra - Adam's Polishes Forums - Threads Tagged with bra I did a TAG search for "bra". Cheers In the picture what is the polisher laying on?? It looked to me like a pad that you could use to put your knees on when polishing the sides of the car?...of course that was just a guess.
07RS4 Posted May 11, 2012 Posted May 11, 2012 What are you talking about? Here's a great link to many threads on the subject. bra - Adam's Polishes Forums - Threads Tagged with bra I did a TAG search for "bra". Cheers He's talking about the knee saver pad Chris...
mc2hill Posted May 12, 2012 Posted May 12, 2012 The kneeling pad looks great! I was thinking about using knee pads this weekend. Where are those pads at? It's called a KneeGrip and Dave (Innovative Detailing) has them on his retail site.
Griffinto
Thanks in advance!
10 answers to this question
