pharden Posted April 18, 2012 Share Posted April 18, 2012 I just picked up a used Lincoln MKS that has dried wax al over the plastic trim. I tried APC and IPA with very minimal improvement.Any suggestions on what else to try? Link to comment Share on other sites More sharing options...
ExpressThis13 Posted April 18, 2012 Share Posted April 18, 2012 peanut butter Link to comment Share on other sites More sharing options...
07RS4 Posted April 18, 2012 Share Posted April 18, 2012 Pics? Dang the previous owner. This is why taking the time to tape up the car FULLY is soooo important. It is a PIA to get that off, especially if the prior user never dressed the trim and its dried and cacked in the pores now. You could try a stiffer brush (one that won't scratch paint of course) with the APC or even some 3m adhesive remover...but highly doubt that will work if what you have tried hasn't worked yet. Once all Adam's products are exhausted...research a product that is a more permanent solution to your problem. Kind of like a trim paint, some of these last a few years and look great if prepped and taped off properly. Link to comment Share on other sites More sharing options...
XQIZT Posted April 19, 2012 Share Posted April 19, 2012 Is it textured or smooth plastic? If textured, try an old tooth brush with APC on it...or a new tennis ball. Gently. Link to comment Share on other sites More sharing options...
Chris@Adams Posted April 19, 2012 Share Posted April 19, 2012 Is it textured or smooth plastic? If textured, try an old tooth brush with APC on it...or a new tennis ball. Gently. Mike, I almost forgot about the tennis ball trick. Link to comment Share on other sites More sharing options...
pharden Posted April 19, 2012 Author Share Posted April 19, 2012 It's textured plastic. What's the tennis ball trick? Has anyone tried magic erasers to remove the dried wax? Link to comment Share on other sites More sharing options...
XQIZT Posted April 19, 2012 Share Posted April 19, 2012 Use a tennis ball as a scrubber. The fuzz works well to get in the texture. Just go gently. Magic erasers might be harsh on some surfaces. As with anything, test on a small area first. Remotely posted by XQIZT Automotive Link to comment Share on other sites More sharing options...
Z71_Denali Posted April 19, 2012 Share Posted April 19, 2012 i've had success with full strength APC. put the nozzle on "stream" spray the affected areas being careful not to hit the paint. rub it in with your finger or the trim/lug nut brush. wipe it off with a junk microfiber or edgeless utility towel. Link to comment Share on other sites More sharing options...
JBlack151 Posted April 19, 2012 Share Posted April 19, 2012 Keep us updated on what you end up using and what worked for you. I'd like to try the tennis ball trick if I come across some a vehicle in need. Link to comment Share on other sites More sharing options...
THE Mook Posted April 19, 2012 Share Posted April 19, 2012 As in our new polishing videos, dressing the trim prior to polish not only saves you a step but also protects the trim from this. Simply grab a MF towel and wipe it off, should the trim already be dressed and you are polishing. That's how I do it anyway. Link to comment Share on other sites More sharing options...
JBlack151 Posted April 19, 2012 Share Posted April 19, 2012 As in our new polishing videos, dressing the trim prior to polish not only saves you a step but also protects the trim from this. Simply grab a MF towel and wipe it off, should the trim already be dressed and you are polishing. That's how I do it anyway. I was always taping off the vehicles when polishing, but recently I've been doing this method and maybe only taping off certain areas (depending on the vehicle). So far it's working out great for me and saving time. Link to comment Share on other sites More sharing options...
07RS4 Posted April 19, 2012 Share Posted April 19, 2012 I was always taping off the vehicles when polishing, but recently I've been doing this method and maybe only taping off certain areas (depending on the vehicle). So far it's working out great for me and saving time. For me, it's more than just nicking the trim with some polish. I tape off everything where I don't want dusting, splatter, polish....anything that has to do with the polishing process. More than once, just when I'm wrapping up the SVRT/IUS on a vehicle...I notice some splatter in a door crease or hood crease somewhere that's a pain to clean up/out. Plus, I feel much more secure whenevery thing is taped up properly...and the polishing process goes that much smoother. Just my thought process. Link to comment Share on other sites More sharing options...
pharden Posted April 19, 2012 Author Share Posted April 19, 2012 Well I tried the peanut butter trick and to my amazement it worked very well after I left it on over night. Plan on doing more areas tonite, while the family isn't watching. Link to comment Share on other sites More sharing options...
Z71_Denali Posted April 19, 2012 Share Posted April 19, 2012 Well I tried the peanut butter trick and to my amazement it worked very well after I left it on over night. Plan on doing more areas tonite, while the family isn't watching. when i had my camaro, i used peanut oil to remove overspray on the vinyl stripes. they must work the same way if you got any on the paint, re-wax that area, because it'll strip wax from paint too! Link to comment Share on other sites More sharing options...
pharden
13 answers to this question
