bobbagels Posted April 23, 2012 Share Posted April 23, 2012 hello hello, Been paint correcting for last 2 days. I did 2 bucket washe, clayed, swirl remover (a couple areas needed severe) and then machine polish. She was lookin good. Then I put the machine sealant on. I put a thin coat on with the PC just like in the videos. Waited about 30-40 min and wiped it down. Now there seems like a haze there. As if all the machine sealant dosent want to come off completely. And I tried. I can slightly see the marks from the gray pad where the sealant went on. (kinda) What did I do wrong? Link to comment Share on other sites More sharing options...
Chuckkilo3 Posted April 23, 2012 Share Posted April 23, 2012 Did you try using some detail spray to wipe the haze off? It's probably a little thicker than you thought it was. Detail spray and a microfiber towel should take it off. Link to comment Share on other sites More sharing options...
BlueGenCoupe Posted April 23, 2012 Share Posted April 23, 2012 Did you try using some detail spray to wipe the haze off? It's probably a little thicker than you thought it was. Detail spray and a microfiber towel should take it off. I agree, try wiping off with DS Link to comment Share on other sites More sharing options...
egott_91 Posted April 23, 2012 Share Posted April 23, 2012 X3 little detail spray and a single or double soft and you should be golden. Link to comment Share on other sites More sharing options...
bobbagels Posted April 23, 2012 Author Share Posted April 23, 2012 Ahh ok, should I wipe with detail spray now or wait for the 12 hour cure time to pass first? Link to comment Share on other sites More sharing options...
BlueGenCoupe Posted April 23, 2012 Share Posted April 23, 2012 Ahh ok, should I wipe with detail spray now or wait for the 12 hour cure time to pass first? Normally after u apply mss u wipe off 30 mins or so later. Then You wait 12-24 hours to cure then you wipe it down again. I would wait till it cures then wipe it down with DS Link to comment Share on other sites More sharing options...
mc2hill Posted April 23, 2012 Share Posted April 23, 2012 Ahh ok, should I wipe with detail spray now or wait for the 12 hour cure time to pass first? Wipe it now to remove the haze. Link to comment Share on other sites More sharing options...
bobbagels Posted April 23, 2012 Author Share Posted April 23, 2012 "I would wait till it cures then wipe it down with Detail Spray" "Wipe it now to remove the haze." Heh, <-- closes eyes, flips coin":help: Link to comment Share on other sites More sharing options...
BlueGenCoupe Posted April 23, 2012 Share Posted April 23, 2012 Everyone details differently. Link to comment Share on other sites More sharing options...
egott_91 Posted April 23, 2012 Share Posted April 23, 2012 Up to you. Either way you'll be fine. Link to comment Share on other sites More sharing options...
Marylander Posted April 23, 2012 Share Posted April 23, 2012 I put on the mss, wait about hour, then wipe off the residue. 24 hours later I come back and wipe the car down again to remove the "secondary" light haze that develops. And then I stand back and admire. Link to comment Share on other sites More sharing options...
bobbagels
hello hello,
10 answers to this question
