Who has Painted Their Calipers Before?
DTrem13
I'm thinking about painting my calipers on my car sometime soon. Either Red or Blue. I think both would look great, but everyone has red, and blue might be a change. What are your thoughts and opinions?
Also, how much of a process is it? Is it easier to paint them while attached to the rotor, or would I get a better end result if I were to take the calipers off?
Any advice would help out a lot! :2thumbs:
I painted mine by myself without taking them off (also have a charger). It's fairly easy, the main thing is to make sure you don't let it run onto the pad.
I used the G2 Blue paint. It comes with everything you need except a wire brush and a low grit sandpaper.
Looks awesome bro
Sent from Picture This! Auto Care
I was just about to PM you Matt :D
The blue looks great! I may go for that color too.
How much of a pain is it to take off the calipers? I've never done that :o but I'm sure I am capable of doing it once I know how haha. I'll do some research online.
Thanks!
since im afraid of brakes and taking them off i just left them on. The main thing is prep work prep work prepwork And cleaning and more cleaning. Since im assuming your doing these on a vehcile that has a few thousand miles i would pull the calibers so you can clean them really well.
I did mine in place a few days after i took delivery of my Mini, taping is the worst imo but i carefully hit them with brake parts cleaner and they were as good as new, only had 60 or so miles on them.
my process was a bit different as i had to match my mirror caps and there was no brake caliber paint that would match them. So i went to my automotive paint store and they matched the plastic mirrors near perfectly. These were done with a self etching primer 2 coats, 4 coats of bascoat and then 5 coats of clear. over 10k miles and not a single issue. :D
When I bought my SS a few year back the previous owner painted the calipers red. After a year or so I noticed them chipping or fading to a light red or pink color.
I purchased some G2 black caliper paint and removed the previous color with sand paper and a wire brush. I then masked off the rotors and lines around the caliper. The G2 kit uses a brush to apply which worked well. They came out great, however next time I plan on taking the calipers off and grinding down the calipers better to give them that smooth look. Or just get them powder coated by someone.
Good luck. It's not a tough job, and you'll be happy with the results. :2thumbs:
Here are some pics of them from a while ago. I've sinced then upgraded to R1 cross drilled and slotted rotors and began my addiction to Adam's to take care of that dirty undercarriage!
I did red calipers on my red audi, and black calipers on my grey VW. Honestly, I think colors that blend in look classier than colors that really stand out, unless of course you're really going for the "pop" factor. Think long term -- two years from now will you appreciate the subtle finishing of a low-key color or be a little embarrassed by racy stand-out colors?
Then there are other dilemmas... on my very original MR2 I can't bring myself to paint the calipers, as much as I truly want to.... :lolsmack:
I wouldn't mind taking the calipers off. It seems like it would be nice to know how to do. And then I can do a VERY good job cleaning them and doing a good job with the paint.
Matt, what was the benefit of painting the rotor? I don't really see it, unless it's just because of the angle of the picture? :lolsmack:
That's a very good point. I think that they both seem to be a bit low key. Everyone (around here at least) seems to have red, so I may go with blue, and try to get the smoothest look I can, so I'm thinking about taking the calipers off and really taking my time and doing a good job.
Plan on claying your whole car afterwards if you don't cover it like Brendon did in his photos.
I had to clay my whole Tahoe after painting my calipers. I didn't think overspray would be as bad as it was.
+1+1+1+1+1+1
i cant stress that enough, if your spraying them in place just carefully cover the whole car, took me 10 minutes. Much better then 1 1/2 hours of claying :D:jester:
Just a couple tips,
Use Caliper paint. It's made specifically for Calipers, and has a high temp rating.
Clean the crap out your calipers. I think I used a solvent such as goof off, or something similar. I also used scuff pads and cleaned them very well.
Bury those calipers in paint. Do not me scared to cover them well. Most calipers are textured and will soak up a lot of product.
I remember doing something like 9-10 coats on mine and they came out awesome. I'd put a few coats, let them sit for awhile and cure, then come back and coat again.
So be patient.
:eek:
Looks like I'll be taking them off then! I don't have a car cover since she's my DD. Overall I think they would look better if I were to take them off the car and take my time since it's my first time.
:eek:
You don't NEED to spray them. The G2 is a brush on paint.
Stupid question time, what happens when you get the paint on the pads?
I'm sure it would cause a ton of brake dust, and it would probably stop you from stopping the car in normal time. Maybe even warp the rotors? Not sure.
i believe yall may be either over estimating the strength of paint...over under estimating the strength of steel here lol. if you get a bit of paint of the pads, the first time you romp on the brakes it'll wear off. but you may increase stopping distance for a bit. take the pads off to paint to be safe.
