Knowing when to make your progression
Isaacrn
Posted
I have a question that I can't seem to find a thread about, and am unsure if anyone else might have the same question.
I am relating polishing a car to polishing straight razors. I shave with straight razors, and when I sharpen them (hone) i use different grits. Lower grits remove more damage, and then you step up to create a polished comfortable edge.
Now I am planning on sticking to the higher grits for the correction of paint. Now when I hone a razor, have have a feeling when it is time to move up in grits, or sometimes you can look in a jeweler loupe to see the edge. My question is when do you know to move up in your polish? I have seen videos where some people will take several passes with Severe Swirl or plain Swirl and Haze remover. If I make lets say 2 passes of Severe Swirl and Haze remover, what would i do when i step down to Swirl and Haze remover? Since most of the surface scratches should be done from the SSHR, do you need as many passes? How do you know when you've reached full potential with that polish?
When I first started reading and watching, I assumed once you flashed the polish you were done with that step. This was until I saw a video where Junkman said he needed another 2 or 3 passes with SSHR. This had me thinking about honing my razors. I certainly don't want to overwork the paint.
I am thinking the polishes might need 1-2 passes depending on the circumstances while polishes and sealants will only take one pass. Am I correct on this thinking?
9 answers to this question
Posted
Good analogy!
That's were the 2'x2' test area (or test areas, if needed) come in. You work the SSR until it looks good, then move to SHR. If one section pass looks good then finish with FMP. If not, try another pass of SHR, then FMP again. Say you did 2 passes of SSR, then 2 passes of SHR in one test area, maybe try 2 passes of SSR followed by 1 of SHR in another and compare the two. Always work back down to FMP before making your final decision, as it really makes a difference. I have split the hood into 6 sections just to see what really worked (keep a Sharpie marker handy to note what was done in each section).
As Dylan often says, paint correction is part science and part art!
Posted
I shave with women's razors...
er, umm
If thats what works for you, there is no shame in it
This is what I am using this week
Posted
That is cool!!:glasses:Do you have a whole collection?
I have several straight razors, and a couple of dozen different types of shaving brushes. Its one of my other hobbies :lol:
Posted
I was checking out some razors & brushes awhile back on line, you can defiantly get some money tied up in them. I would be afraid to save my head with one though.:help:
Posted
It can be done...although it would take some cajones..haha. I have seen videos online of the whole ordeal. If I ever needed to shave my head, I would definitely give it a go.
If you ever want to enter the world of straight shaving, or wet shaving send me a PM and we can see about answering some questions :)
Posted
Will do.
