Last week I setup a camera to film my entire wash process from start to finish, mainly at the request of a customer who had seen how my Avalanche had looked thru most of its life. He has been struggling to keep his black truck swirl free and wanted to know how I did it. What better way than to just show the process, start to finish. Obviously I've sped this up so you don't have to watch me wash a truck for an hour+, but it is uncut... start to finish... how I wash my rides to minimize swirling.
So why 3 buckets?
I started to notice that in some of my washes the 2nd bucket was still getting a fair amount of grit in the bottom. Wanting to eliminate the chances it made it back to the paint I added a 3rd bucket with another grit guard. My goal is to have ZERO contamination by the time I make it to that last bucket.
Bucket 1:
Pure water. this is used to scrub loose the majority of the debris. The wash media is scrubbed against the insert, combed thru with my fingers and given a quick visual inspection.
Bucket 2:
Pure water. This bucket gets much the same process as the first, once again scrubbing against the grit guard, pulling out of the water and inspecting for debris.
Bucket 3:
Water with soap. When your wash mitt reaches this bucket it should be clean and free of debris minimizing your chances of swirling. Make sure the mixture is heavy and a thick later of soap is created at setup.
You'll also notice the addition of a foam gun to the process. I'd like to stress this is NOT a requirement, but more a thing of convenience. Using solid technique you can perform a proper swirl free wash without a foam gun... it just makes it faster/easier. Also, before anyone says anything - the gun I'm using is actually from the pre-china gilmour days... I've had it for awhile.
The process itself is pretty basic.
Start with the wheels as always.
Rinse really well before introducing soap.
Foam the vehicle completely.
Merino Wash Mitt for the upper 2/3rds working 1 panel with each side of the mitt.
Rinse. Inspect. Rinse. Inspect. Prime and repeat.
Switch over to 2nd wash mitt or pad for lower 1/3rd following same process.
Optional - Foam the vehicle again anywhere the soap may have started to dry.
Power rinse with a strong stream from the hose.
Sheet rinse to reduce standing water.
Blaster Sidekick to knock loose bulk of remaining water.
Great White Drying Towel + Detail Spray to dry
Hit again with Blaster Sidekick to get water out of cracks.
Touchup with Great White + Detail Spray
Waterless Wash + Waterless Wash Towel for door jambs, engine bay, and wheels.
Total time start to finish for this wash was 1h 17m
Team Adam's
So why 3 buckets?
Bucket 1:
Bucket 2:
Bucket 3:
Edited by Dylan@AdamsTop Posters For This Question
14
5
5
4
Popular Days
May 8
30
May 10
9
May 11
8
May 9
5
Team Adam's 14 posts
LDM 5 posts
Corners 5 posts
manishaudi 4 posts
Popular Days
May 8 2012
May 10 2012
May 11 2012
May 9 2012
Popular Posts
InDepthAutoDetailing
Dylan, something I've been doing since my truck is swirl free is spraying waterless wash in all the cracks, let it sit while I do the tires, then rinse those areas really well before I hit it with the
88 answers to this question
