jwright0291 Posted May 30, 2012 Share Posted May 30, 2012 I have a '75 cb750 motor that i need to clean really good. First off, whats the best way to get all the oil and grime off? And next, the paint is coming off the cooling fins, so i want to remove the paint completely to repaint, should i use steel wool? Link to comment Share on other sites More sharing options...
0 Chewy Posted May 30, 2012 Share Posted May 30, 2012 (edited) If you're painting it, first use a stiff brush and kerosene to get the built on gunk off. It's the best way. Then clean with APC and a finer brush like the wheel brush to get the kerosene and any other left over oils off. You need to put a key in the paint and the metal for the new paint to stick. Scotch Bright pads work well for this. Burgandy color is the medium abrasive and should work well. Prime and paint using engine specific paint only. I believe VHT makes some. Chris Edited May 30, 2012 by Chewy Link to comment Share on other sites More sharing options...
0 jwright0291 Posted May 30, 2012 Author Share Posted May 30, 2012 If you're painting it, first use a stiff brush and kerosene to get the built on gunk off. It's the best way. Then clean with APC and a finer brush like the wheel brush to get the kerosene and any other left over oils off. You need to put a key in the paint and the metal for the new paint to stick. Scotch Bright pads work well for this. Burgandy color is the medium abrasive and should work well. Prime and paint using engine specific paint only. I believe VRT makes some. Chris Thanks buddy. Link to comment Share on other sites More sharing options...
0 Redbeard Posted May 30, 2012 Share Posted May 30, 2012 Prime and paint using engine specific paint only. I believe VRT makes some. Chris You've got Adam's products on the brain. I think you mean VHT. http://www.vhtpaint.com/ Link to comment Share on other sites More sharing options...
0 Chewy Posted May 30, 2012 Share Posted May 30, 2012 You've got Adam's products on the brain. I think you mean VHT. VHT Hahaha... I did sorry! Link to comment Share on other sites More sharing options...
jwright0291
4 answers to this question
