Sandalwood Posted July 5, 2012 Share Posted July 5, 2012 Looking into getting one of these products... What are the major differences? Looks like the Vac n Blow is a vacuum on top of being able to dry out the crevices like the sidekick ? Quote Link to comment Share on other sites More sharing options...
0 mc2hill Posted July 5, 2012 Share Posted July 5, 2012 You can use the 500 to blow some water off the car, but it does not have much power for doing this. Also you are blowing 'dirty' air too. But then you cannot use the Sidekick to vacuum at all! If you already have a vac, then definitely get the Sidekick. It is not as powerful at the Master Blaster and is not for drying the whole car, but it does a great job of removing water from areas that puddle and hide water - roof rails, emblems, moldings, lug nut holes in the wheels, door jambs, etc. Also good for drying the tires before using SVRT. Quote Link to comment Share on other sites More sharing options...
0 gymrat7953 Posted July 5, 2012 Share Posted July 5, 2012 Master blaster is the way to go. Quote Link to comment Share on other sites More sharing options...
0 Sandalwood Posted July 5, 2012 Author Share Posted July 5, 2012 Master blaster is the way to go. Quote Link to comment Share on other sites More sharing options...
0 Sandalwood Posted July 5, 2012 Author Share Posted July 5, 2012 You can use the 500 to blow some water off the car, but it does not have much power for doing this. Also you are blowing 'dirty' air too. But then you cannot use the Sidekick to vacuum at all!If you already have a vac, then definitely get the Sidekick. It is not as powerful at the Master Blaster and is not for drying the whole car, but it does a great job of removing water from areas that puddle and hide water - roof rails, emblems, moldings, lug nut holes in the wheels, door jambs, etc. Also good for drying the tires before using SVRT. I'm not looking to dry off the whole car, just blow water out of crevices.. Quote Link to comment Share on other sites More sharing options...
0 JBlack151 Posted July 5, 2012 Share Posted July 5, 2012 I'm not looking to dry off the whole car, just blow water out of crevices.. Then get the sidekick. It works great for getting the water out of the crevices. I use it on so many areas the water loves to hide! Quote Link to comment Share on other sites More sharing options...
0 BlueGenCoupe Posted July 6, 2012 Share Posted July 6, 2012 I'm not looking to dry off the whole car, just blow water out of crevices.. Sidekick will do the job, but If funds aren't an issue I would go masterblaster Quote Link to comment Share on other sites More sharing options...
0 DaveVY Posted July 6, 2012 Share Posted July 6, 2012 I have the Vac n Blow 500. For crevices I tried using it but found that my electric leaf blower works much better. It is a useful and convenient little vac for a car that is regularly maintained but IMHO is too slow for doing deep cleaning on really dirty vehicles. The bag on the vac is very small and should be dumped after every. Overall it is a great little unit for home/individual vac use but I don't like it or use it for the blower function. Quote Link to comment Share on other sites More sharing options...
0 Redvenm Posted July 6, 2012 Share Posted July 6, 2012 If you are only looking for limited water removal, the sidekick works great. The other use I really like from this lil guy is to remove dust. Small quick and does a great job, makes the ww process easier or even not necessary at times. Quote Link to comment Share on other sites More sharing options...
0 THE Mook Posted July 6, 2012 Share Posted July 6, 2012 Sidekick. I have one. I love the heck out of it. Quote Link to comment Share on other sites More sharing options...
0 Kustom_FX Posted July 6, 2012 Share Posted July 6, 2012 Yea I acquired a Sidekick from a guy I work with... He got all this Adam's stuff and it just sits.. So I use it now and LOVE LOVE LOVE it! Quote Link to comment Share on other sites More sharing options...
0 skippyburger Posted July 10, 2012 Share Posted July 10, 2012 Why doesn't anyone ever consider an air compressor when these discussions come up? I'm sure there is a good reason not to, I just can't think of it. In my opinion, a compressor is unbeatable for air pressure and can dry the whole car or just use it for cracks and crevices. There's also the aspects of cleaning and blowing out your pads and tools along with maintaining tire pressure and so on. Quote Link to comment Share on other sites More sharing options...
0 DaveVY Posted July 10, 2012 Share Posted July 10, 2012 Why doesn't anyone ever consider an air compressor when these discussions come up? I'm sure there is a good reason not to, I just can't think of it. In my opinion, a compressor is unbeatable for air pressure and can dry the whole car or just use it for cracks and crevices. There's also the aspects of cleaning and blowing out your pads and tools along with maintaining tire pressure and so on. I won't use an air compressor for a couple reasons: 1) Typical consumer grade air compressors won't have enough air volume. They have pressure in a very small stream but not the volume to effectively dry a large surface 2) Typical consumer grade air compressors are not designed to run constantly but just every few minutes to boost the pressure up. If they run constantly moisture will form and then the air stream coming out of the hose is not dry air but moist air. Most people don't drain the moisture from their tanks like they should and using an air compressor in this manner will just make the moisture problem worse. 3) Volume for volume, air compressors cost more than a blower. If you already have an air compressor you can try using it for this purpose. When I started detailing I tried using my air compressor but found that my electric leaf blower was faster and more effective for removing excess water from the car. Quote Link to comment Share on other sites More sharing options...
0 Redvenm Posted July 10, 2012 Share Posted July 10, 2012 In my business we use 2 large compressors to run a dozen nail guns. Over time the moisture does build up as mentioned as well as internal rusting. Ours are drained nightly and still there is a chance of moisture and rust particles to be blasted onto your paint. Not worth the risk in my mind! Quote Link to comment Share on other sites More sharing options...
0 DTrem13 Posted July 10, 2012 Share Posted July 10, 2012 I used to use a compressor before I purchased the Blaster Sidekick. It was decent for not having another option, but the compressor was always running (trying to refill the tank as I was using it.) The Blaster Sidekick is a much better option for car use. It's worth every penny. Sent from my DROID RAZR MAXX using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
0 Z71_Denali Posted July 10, 2012 Share Posted July 10, 2012 i own both! for someone that doesn't have a place for the big daddy versions, both are essential. since you could always go to a coin op to use their vacuums without damaging anything, the sidekick is probably the one you want first. stay tuned i might be "giving" my vac-n-blo 500 away in August after my b-day (minus shipping and handling). the jumbo vac-n-blo is on my list. Quote Link to comment Share on other sites More sharing options...
0 goodmanXX3 Posted July 10, 2012 Share Posted July 10, 2012 blaster sidekick is a must have imo. i refuse to wash my car w/o having it handy i.e. out of town etc. Quote Link to comment Share on other sites More sharing options...
Sandalwood
16 answers to this question
