USMC- FRS Posted February 10, 2013 Share Posted February 10, 2013 Guys. I just bought the PC and need to know prior to me polishing my car do I need to strip the existing wax on the car now. OTC stuff. Also I plan on flaying the entire vehicle as well. Any advise would be appreciated. Thanks Link to comment Share on other sites More sharing options...
0 GXPaycheck Posted February 10, 2013 Share Posted February 10, 2013 IPA wipe down. It's easier to search for existing threads than start a new one. You could also wash with Dawn or mix some APC in the wash water. Link to comment Share on other sites More sharing options...
0 USMC- FRS Posted February 10, 2013 Author Share Posted February 10, 2013 Yes good advise. I just found a few good threads. What is IPA Link to comment Share on other sites More sharing options...
0 mc2hill Posted February 11, 2013 Share Posted February 11, 2013 Yes good advise. I just found a few good threads. What is IPA isopropyl alcohol, found in drug or grocery stores. Mix with water to about 50/50. Link to comment Share on other sites More sharing options...
0 GaryW Posted February 11, 2013 Share Posted February 11, 2013 isopropyl alcohol, found in drug or grocery stores. Mix with water to about 50/50. Just did this process this weekend. Washed with dawn and APC mixed,,, used the IPA to spray and wipe off,,, polished SHR and MFP. IPA again just incase. then MSS. Followed the next day with BG and Americana. I had clayed the car the previous weekend... But hit a few spots any way again. Watch the videos over and over and ask all the questions on here you Need. Link to comment Share on other sites More sharing options...
0 BRZN Posted February 11, 2013 Share Posted February 11, 2013 Do you have to? No, but it's a good idea as it can make the polishing go much better. The polishing step will remove any wax left on the vehicle, but the wax could begin to clog the pores of the pad making them much less effective. What about the clay step, you going to do that? If not, any contaminents remaining on the paint could be pulled into the pad causing some marring. Link to comment Share on other sites More sharing options...
0 ihaveacamaro Posted February 13, 2013 Share Posted February 13, 2013 Americana wax is a high quality wax. If you used it, I can almost guarantee you that an IPA wipedown alone won't remove it. In fact, I would say that for just about any *quality* wax. Do the 2 bucket wash with 3 to 4 ounces of all purpose cleaner in the wash as well and that, in combination with claying, should remove most of the existing wax, whatever it is. Link to comment Share on other sites More sharing options...
0 USMC- FRS Posted February 17, 2013 Author Share Posted February 17, 2013 Thanks guys for all the great advise. I plan on following GARYW advise. The only wax that was on the car was OTC Mothers Gold Carnauba wax. It's going to be only 45 degrees today outside temp. Will it be ok to Clay the car in the garage? Also what is MFP. Also one last question do I mix the 50/50 isopropyl alcohol and water in a spray bottle and wipe the in tire car after flaying, washing with Dawn and prior to swirl and haze polish. I think I have it right. Thanks for all the support. Joe Link to comment Share on other sites More sharing options...
0 GXPaycheck Posted February 17, 2013 Share Posted February 17, 2013 I think he meant FMP (fine machine polish). If you wipe with IPA, you won't need the Dawn wash. If you use dawn make sure you treat the plastics with VRT. Dawn will dry them out. You can clay inside. I would suggest doing one section at a time. Get one right before you do the rest of the car. Link to comment Share on other sites More sharing options...
0 USMC- FRS Posted February 18, 2013 Author Share Posted February 18, 2013 Thanks to all who provided feedback and advise. Tried a test section today and I can't believe the results. Very happy with these products and the PC 7424. God bless America. Link to comment Share on other sites More sharing options...
0 GaryW Posted February 18, 2013 Share Posted February 18, 2013 Thanks to all who provided feedback and advise. Tried a test section today and I can't believe the results. Very happy with these products and the PC 7424. God bless America. Your on the right track now. Strip wash, hit with IPA, polish then IPA again before sealant and wax. Remember to take your time, do not get into a rush. That is when you will start missing up. If you have to do one or 2 panels a day do it that way. First time I did it, tried doing the whole car in one day and that was starting at like 2pm. I was wore out and did not get the results I wanted. Granted the car was glowing, but nothing like she could of. Watch the videos over and over, and ask all questions you need. Link to comment Share on other sites More sharing options...
0 Black out - Anthony Posted February 25, 2013 Share Posted February 25, 2013 that it is enough, washing at karcher in car wash ? there is detergent in the car wash ! it may be sufficient to remove wax and sealant ? no ? Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted February 25, 2013 Share Posted February 25, 2013 Post up some pics when done Joe. Link to comment Share on other sites More sharing options...
0 USMC- FRS Posted February 28, 2013 Author Share Posted February 28, 2013 I will get some up on Friday. Thinking about buying the glaze and Americana wax what's your thoughts. Link to comment Share on other sites More sharing options...
0 Blazer15 Posted February 28, 2013 Share Posted February 28, 2013 I will get some up on Friday. Thinking about buying the glaze and Americana wax what's your thoughts. Do it. You won't have any regrets. Trust me. Link to comment Share on other sites More sharing options...
0 SIERRAAZ Posted February 28, 2013 Share Posted February 28, 2013 Your on the right track now. Strip wash, hit with IPA, polish then IPA again before sealant and wax. Remember to take your time, do not get into a rush. That is when you will start missing up. If you have to do one or 2 panels a day do it that way. First time I did it, tried doing the whole car in one day and that was starting at like 2pm. I was wore out and did not get the results I wanted. Granted the car was glowing, but nothing like she could of. Watch the videos over and over, and ask all questions you need. What if the Car or truck you are correcting is you only means of getting around? Say you need to go some where if you don't finish working on it the first day, when you are ready to work on it again do you hit it with some ww before continuing? Or what is the proper prep before starting again? Link to comment Share on other sites More sharing options...
0 GaryW Posted February 28, 2013 Share Posted February 28, 2013 (edited) What if the Car or truck you are correcting is you only means of getting around? Say you need to go some where if you don't finish working on it the first day, when you are ready to work on it again do you hit it with some ww before continuing? Or what is the proper prep before starting again? If you will not have time to do the whole vehicle, do a section at a time. maybe do the hood and roof, then next day or when ever correct a different part next time. If you are driving the vehicle out and around,, I would do a 2 bucket wash prior to working on paint. If it is just sitting garage, then I would hit it with the WW. Here is a idea I did on car for my friend.. I strip wash entire car. clayed it, Polished the hood and front of car. applied BG and Americana to entire car. Next time I will polish a different part of it. At least I got the clay job done and paint was clean and the entire car looked alot better then it did.... I will wash entire car again when he brings it back to me. But I will only have to strip the part I am going to polish with IPA. Do what you can when you can. Do not try to do the entire car and make it a rush job. You will hate it.. Hope that helps.. Edited February 28, 2013 by GaryW Link to comment Share on other sites More sharing options...
0 USMC- FRS Posted February 28, 2013 Author Share Posted February 28, 2013 Thanks Gary, I did try to rush and made that mistake. What do you want I'm a Marine. We do everything fast. Link to comment Share on other sites More sharing options...
0 GaryW Posted February 28, 2013 Share Posted February 28, 2013 Thanks Gary, I did try to rush and made that mistake. What do you want I'm a Marine. We do everything fast. But now remember: Improvise, Adapt and Overcome Link to comment Share on other sites More sharing options...
0 SIERRAAZ Posted February 28, 2013 Share Posted February 28, 2013 If you will not have time to do the whole vehicle, do a section at a time. maybe do the hood and roof, then next day or when ever correct a different part next time. If you are driving the vehicle out and around,, I would do a 2 bucket wash prior to working on paint. If it is just sitting garage, then I would hit it with the WW. Here is a idea I did on car for my friend.. I strip wash entire car. clayed it, Polished the hood and front of car. applied BG and Americana to entire car. Next time I will polish a different part of it. At least I got the clay job done and paint was clean and the entire car looked alot better then it did.... I will wash entire car again when he brings it back to me. But I will only have to strip the part I am going to polish with IPA. Do what you can when you can. Do not try to do the entire car and make it a rush job. You will hate it.. Hope that helps.. Great info! thanks for the tips! Link to comment Share on other sites More sharing options...
0 ihaveacamaro Posted February 28, 2013 Share Posted February 28, 2013 If you will not have time to do the whole vehicle, do a section at a time. maybe do the hood and roof, then next day or when ever correct a different part next time. If you are driving the vehicle out and around,, I would do a 2 bucket wash prior to working on paint. If it is just sitting garage, then I would hit it with the WW. Here is a idea I did on car for my friend.. I strip wash entire car. clayed it, Polished the hood and front of car. applied BG and Americana to entire car. Next time I will polish a different part of it. At least I got the clay job done and paint was clean and the entire car looked alot better then it did.... I will wash entire car again when he brings it back to me. But I will only have to strip the part I am going to polish with IPA. Do what you can when you can. Do not try to do the entire car and make it a rush job. You will hate it.. Hope that helps.. I'm not trying to start an argument or anything, but I can guarantee you that IPA is not removing the wax off the car from the section you will be doing next. Americana will not be removed that easily. Link to comment Share on other sites More sharing options...
0 SIERRAAZ Posted February 28, 2013 Share Posted February 28, 2013 I'm not trying to start an argument or anything, but I can guarantee you that IPA is not removing the wax off the car from the section you will be doing next. Americana will not be removed that easily. haha jk. Link to comment Share on other sites More sharing options...
0 USMC- FRS Posted March 1, 2013 Author Share Posted March 1, 2013 These products work great. Ordered the glaze and Americana wax today Link to comment Share on other sites More sharing options...
0 GaryW Posted March 1, 2013 Share Posted March 1, 2013 Good Deal. I got a black 2012 Impala I am working on this weekend. See how that goes if I can get some photos to post. Link to comment Share on other sites More sharing options...
0 USMC- FRS Posted March 1, 2013 Author Share Posted March 1, 2013 Cool deal, can't wait to see them. I going to a Cars and Coffee tomorrow can't wait to show off the shine. I ordered the glaze and Americana wax today. Link to comment Share on other sites More sharing options...
USMC- FRS
Thanks
24 answers to this question
