Black out - Anthony Posted February 22, 2013 Share Posted February 22, 2013 a few questions: waterless wash away the wax and sealant? I just apply the sealant at 8am this morning and this afternoon I towels and I have a hard time removing some traces. this is serious? in 24h I essuis again. I have removed all traces well before the brilliant glaze or is it okay? it is a black car so we see many traces. Annuler les modifications Alpha Link to comment Share on other sites More sharing options...
0 redneck08sierra Posted February 22, 2013 Share Posted February 22, 2013 sorry but after your first question, you lost me. no, waterless wash will not wash away the wax and sealant. Only possibility it may remove it is if you didn't allow you sealant time to cure but I don't think this would happen Link to comment Share on other sites More sharing options...
0 Brandon Lutz Posted February 22, 2013 Share Posted February 22, 2013 How long did you wait to remove the sealant after you applied it? Depending on weather conditions, I let the sealant sit and bond to the paint for about 20 to 30 minutes before removing. If you wait too long to remove it the harder it will be to remove the dried haze. Also if you did not wait long enough for it to cure properly, that can make it difficult to remove as well. In the areas that are still hazy, try spraying the area with some detail spray. Let the detail spray sit for a few seconds and then wipe/buff off. That should help make the removal easier. Link to comment Share on other sites More sharing options...
0 Tim Posted February 22, 2013 Share Posted February 22, 2013 Which sealant? Machine Super Sealant or Quick Sealant? If you are left with some "stick spots" you can try a ds wipedown. If it is really bad, you may need to use IPA and go over that area with the sealant again. Link to comment Share on other sites More sharing options...
0 Black out - Anthony Posted February 22, 2013 Author Share Posted February 22, 2013 is the Machine super sealant. I have no ipa. I can remove it with all purpose cleaner? the team, you have a board?:help: Link to comment Share on other sites More sharing options...
0 Black out - Anthony Posted February 22, 2013 Author Share Posted February 22, 2013 the detail spray residues removed. oufff wow the frenchy s hit in his pants Link to comment Share on other sites More sharing options...
0 Tim Posted February 22, 2013 Share Posted February 22, 2013 Anthony, are you good? I'm trying to make sure nothing is lost in the translation. Link to comment Share on other sites More sharing options...
0 ECaulk Posted February 23, 2013 Share Posted February 23, 2013 is the Machine super sealant. I have no ipa. I can remove it with all purpose cleaner? the team, you have a board?:help: Did you apply the machine super sealant let it cure and then wipe it down (~30min cure time cooler weather ~1hour) then no addition sealant or waxes for a minimum of 12 hours (again warm weather) to 24hours (cooler weather). The machine super sealant takes time to cure. Link to comment Share on other sites More sharing options...
0 Black out - Anthony Posted February 24, 2013 Author Share Posted February 24, 2013 Anthony, are you good? I'm trying to make sure nothing is lost in the translation. :lolsmack:I was very scared.lol. after being destroyed by a bad detailer he came to see me for polishing Link to comment Share on other sites More sharing options...
Black out - Anthony
a few questions:
Alpha
8 answers to this question
