JapaTree Posted March 13, 2013 Share Posted March 13, 2013 Every time I try to checkout I get this Error. I am stationed in Okinawa, Japan so its very hard to be able to call in a order. This is the third time I have missed out on the Daily Special:(. I just emailed Mook@AdamsPolishes.com so hopefully he can get this last daily special order in for me. I am now out of Detail Spray:help: Server Error in '/' Application. Object reference not set to an instance of an object. Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code. Exception Details: System.NullReferenceException: Object reference not set to an instance of an object. Source Error: Line 356: pnlCartAllowsShippingMethodSelection.Visible = cart.CartAllowsShippingMethodSelection; Line 357: Line 358: String ShipMethods = cart.GetShippingMethodList(String.Empty, out AnyShippingMethodsFound); Line 359: ShippingOptions.Text = ShipMethods; Line 360: Source File: c:\Websites\AdamsPolishes.com\checkoutshipping.asp x.cs Line: 358 Stack Trace: [NullReferenceException: Object reference not set to an instance of an object.] AspDotNetStorefrontCore.RTShipping.FedExGetRates(S hipments AllShipments, String& RTShipRequest, String& RTShipResponse, Decimal ExtraFee, Decimal MarkupPercent, Decimal ShipmentValue, Decimal ShippingTaxRate, Boolean smartpost) in C:\inetpub\wwwroot\AspDotNetStorefront8.0.1.4\ASPD NSFCore\FedEx.cs:451 AspDotNetStorefrontCore.RTShipping.GetRates(Shipme nts AllShipments, String Carriers, ResultType ListFormat, String FieldName, String CssClass, Decimal ShippingTaxRate, String& RTShipRequest, String& RTShipResponse, Decimal ExtraFee, Decimal MarkupPercent, Decimal ShipmentValue) in C:\inetpub\wwwroot\AspDotNetStorefront8.0.1.4\ASPD NSFCore\RTShipping.cs:729 AspDotNetStorefrontCore.ShoppingCart.GetRates(Addr ess shipmentAddress, Decimal ShippingHandlingExtraFee) in C:\inetpub\wwwroot\AspDotNetStorefront8.0.1.4\ASPD NSFCore\ShoppingCart.cs:8088 AspDotNetStorefrontCore.ShoppingCart.GetRates(Deci mal ShippingHandlingExtraFee) in C:\inetpub\wwwroot\AspDotNetStorefront8.0.1.4\ASPD NSFCore\ShoppingCart.cs:7595 AspDotNetStorefrontCore.ShoppingCart.GetRTShipping Rates(Address thisShippingAddress, String FieldSuffix, String FreeIDs) in C:\inetpub\wwwroot\AspDotNetStorefront8.0.1.4\ASPD NSFCore\ShoppingCart.cs:7376 AspDotNetStorefrontCore.ShoppingCart.GetShippingMe thodList(String FieldSuffix, Boolean& AnyShippingMethodsFound) in C:\inetpub\wwwroot\AspDotNetStorefront8.0.1.4\ASPD NSFCore\ShoppingCart.cs:4717 AspDotNetStorefront.checkoutshipping.InitializePag eContent() in c:\Websites\AdamsPolishes.com\checkoutshipping.asp x.cs:358 AspDotNetStorefront.checkoutshipping.Page_Load(Obj ect sender, EventArgs e) in c:\Websites\AdamsPolishes.com\checkoutshipping.asp x.cs:142 System.Web.Util.CalliHelper.EventArgFunctionCaller (IntPtr fp, Object o, Object t, EventArgs e) +14 System.Web.Util.CalliEventHandlerDelegateProxy.Cal lback(Object sender, EventArgs e) +35 System.Web.UI.Control.OnLoad(EventArgs e) +99 System.Web.UI.Control.LoadRecursive() +50 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +627 Link to comment Share on other sites More sharing options...
GaryW Posted March 13, 2013 Share Posted March 13, 2013 I am sure Mook will get you to where you need to be. Bet the bank on it. I tried to order some single soft towels yesterday. I kept getting the message you are ordering more than is in stock. I know they have been out of stock, but there was a message on the screen stating that on product description. I did not see it no more so thought they were back in stock.. NOPE. It also did that with the hex grip pro tire applicator. Have to check back later. Link to comment Share on other sites More sharing options...
Z71_Denali Posted March 13, 2013 Share Posted March 13, 2013 not enough items in your cart Link to comment Share on other sites More sharing options...
Chris@Adams Posted March 13, 2013 Share Posted March 13, 2013 Please call, and they will help you! Contact Us Link to comment Share on other sites More sharing options...
THE Mook Posted March 13, 2013 Share Posted March 13, 2013 I believe you have been answered via email. Short answer, when anyone needing to order with an APO address, please give Ashley a call so she can get you squared up! Thanks! Mook Link to comment Share on other sites More sharing options...
JapaTree Posted March 15, 2013 Author Share Posted March 15, 2013 Everything has been taken care of!!! Thank you Mook and thank you Ashley. Link to comment Share on other sites More sharing options...
