Somedays are good detailing days and others are just plain tedious and frustrating. I used my new Flex for the first time today, and while the results are probably 70%, it's not where I can leave it and be happy.
I'm using the 2 stage process with the foam pads on a 1931 Ford StreetRod painted in Dupont BC/CC the clearcoat almost seems to behave like my BMW, super hard when you need to fix something but will catch a scratch by just looking at it. My Ford collected swirl marks and hazing this show season but nothing extremely deep.
I tried to take pictures of my test area, but the I can't capture what I'm still seeing. Here is a before picture which shows what I'm up against pretty well. I would say the after situation, is much better, but there are still horizontal lines and haze in areas.
None of the marks that are left are in any orbital or round fashion so I don't believe it's being induced by the Flex. When I did my first run with the Flex I was running it at speed 4 for both steps with moderate pressure, but it wasn't cutting that well. I stepped it up to speed 5 and applied more pressure, but seemed like I applied too much pressure because it heated up and I dusted a bit. Last pass was both step at speed 5 but with a little less pressure.
I'm leaning towards one of these 3 issues but I'm only guessing...
Maybe I'm moving too fast through the passes?
Should I step back to speed 4 on the fine polish step? I read a thread on here where it seemed to help with a harder clear coat helped.
Is this an example where a combination of microfiber and foam would help because i need to cut better in step 1?
cayenne
Edited by cayenneLink to comment
4 answers to this question
