A bird decided to place a deposit on my car door yesterday while I was at work. Of course I had just washed the car Sunday evening. I was able to get it all off without scratching anything, however it still ate into the clear coat even though it was only on there a maximum of 3 hours. When I got home I broke out the clay bar in hopes that it would help however it didn’t put a dent in it. I then broke out the Porter Cable and used the Severe Swirl & Haze remover followed by the Swirl & Haze remover and then Buttery Wax. When I was finished it seemed like it may have worked at least a little bit because I could not notice it anymore unless the light was shining on the car at a perfect angle and I was looking at it at a certain angle.
This morning when I got to work I walked around to the passenger side of the car and you can definitely still see it on the car. Is there anything else you can recommend to do to get this out? The finish is glass smooth but you can still see it in the clear coat. Any help would be appreciated. If you need a photo I can try and get one for you. I am hoping that the new Microfiber pads and new Two step Adams paint correcting process will work better than the older 3-step Adams product and the foam pads.
fieldgoal00
3 answers to this question
