tony@rodscustom.com Posted January 2, 2014 Share Posted January 2, 2014 I just ordered a good bti of product and can't wait to start using. When I wet sand with 1500-2000 grit, what is the recommended products and steps to achieve a flawless swirl free finish? Quote Link to comment Share on other sites More sharing options...
0 GXPaycheck Posted January 2, 2014 Share Posted January 2, 2014 Check out The Junkman's videos on you tube. Excellent wet sanding instructions there. Quote Link to comment Share on other sites More sharing options...
0 IowaEmt1991 Posted January 2, 2014 Share Posted January 2, 2014 Make sure you hit it with 3k also. Makes polishing a lot less work. 3k is more a foam than a paper, just and fyi. Severe Swirl remover if needed SHR or paint correcting polish FMP or paint finishing polish Sealeant Glaze Wax Quote Link to comment Share on other sites More sharing options...
0 Team Adam's Posted January 2, 2014 Share Posted January 2, 2014 Microfiber pads and paint correcting polish can cut 2000 grit on most paint jobs, so you'll need those. Follow up with Paint Finishing polish and a white pad and you should be good. The Cyclo, PC, and similar tools aren't going to have the same bite, so you'll want to sand down further if thats what you'll be using. Quote Link to comment Share on other sites More sharing options...
tony@rodscustom.com
3 answers to this question
