So, after using some rinseless wash and obtaining some pretty decent results, my question is, the rinsless wash video says to mix 2 ounces in a 5 gallon bucket and use it to "wash" your vehicle and then when you want to use it as a "waterless wash" Dylan says to mix 1 ounce in a 16 oz bottle. Sure does seem to be a big difference in the way the product works with so much more concentate in the 16 oz bottle compared to the way it is used in the 5 gallon bucket. If that ratio were correct, wouldn't you be using a lot more than 2 ounces in a 5 gallon bucket? I do like the new rinseless wash but have always been a little skeptical about wiping a dry vehicle without anything between the wash mit and the metal on the vehicle. Would it be a little safer to spray some waterless wash or rinsless wash on the vehicle first and then hit with the rinsless wash from the bucket? I did notice a little marring after I used the rinsless wash in a couple of areas but nothing that could not be corrected with a quick wax or buff.
07stanggt
9 answers to this question
