I picked up a truck this weekend with the sole purpose of it being a hauler for Home Improvement runs. I swore it was going to stay as it was bought so I wouldn't be concerned about dirt, etc.
The fact I'm here shows I couldn't allow that, so I'm putting together an attack plan for an interior that looks like the bulk of the dirt was carried INSIDE versus in the bed. The gray is mostly coffee / cola colored so any improvement will be drastic improvement...
Plan is a follows:
1) Gut the interior - pull as much apart as possible to clean aggressively
2) Treat carpet with APC, let sit, then carefully pressure wash clean, hang to dry
3) Bissel steam clean seats pre treating with [need suggestion: CC? APC?] and let dry before re-install.
4) Clean vents with vacuum and dryer vent cleaner thingy, then a microfiber on a stick to wipe clean
5) Clean all plastic parts with diluted APC and then treat with [ TID or VRT or better suggestion?]
6) While interior is out, replace / reseal rear window
- a prev owner used a thin silicone sealer poured into every gap in the trim to stop a leak. Peels out nicely though
7) Try to remove scum layer from under dash / wiring / pedals etc...
- Blast the areas with compressed air and have a fan blowing across the interior
- I plan to use a very diluted APC on a wheel brush which seems to work well on nooks and crannies
- not too damp so I don't short anything out before I can find and fix
8) De-Stink - Attempt to remove the blend of sweat, coffee and hint of smoke. I read that Ozium and window up with vents at full blast can / will work. I'll try that.
9) after re-assembly, wipe down all surfaces with TID.
Are there any words of wisdom for getting out dirt and dust from some of those impossible to reach dash places?
Thanks!
Mak
BTW I notice I don't see the Green or Orange machine polishes on the site anymore, what happened to those? After I don't feel so filthy just getting in the truck, I'll likely polish the outside.
Makrel
Plan is a follows:
Thanks!
Mak
