6 answers to this question
Posted
I use MFRB and the pad cleaning and conditioner brush. Spray MFRB onto pad working in with your fingers and clean with brush and warm water.
Posted
APC works too.  If they are really bad, spray on some APC, then put them in your bucket with some water and a few more sprays of APC, drop the Grit Guard in upside down, and let them soak for a few hours (or days!).  Rinse and clean.  The Grit Guard makes a good washboard too!
Posted
Grit Guard as mentioned , is a great washboard. I lay my pads on the grit guard, take my outdoor hose with nozzle attached, and blast away the wax first. You wont believe the amount of wax that ends up on the ground after you hose them off. Then I use warm to hot water with Dawn dishwashing detergent and knead that into the pads to clean out the rest of the wax. Dry the micrfiber or foam side down on the grit guard and let them dry. I also stole the drying rack from my dryer to let all the other pads/applicators dry as well. Just dont tell my wife, shes been looking for that drying rack forever !!! :)
