clay bar falling apart after one use...
Wickedowesix
Sounds strange, indeed. Especially for a brand new piece of clay.
Post up some pics of it, and shoot me a PM. I'll get a new bar headed your way.
Listen to Nick. :2thumbs:
The older clay did this to me when I first used it. Once it was lubed up nicely it was fine. Sounds like Adam will be helping you out.
Until then: Make sure your hands are CLEAN or use gloves. Spray the clay and work it well. Once you do that, you should not have that issue.
This was the same experience I had with the clay bar... I started a thread about it and tried some of the tips suggested without much luck. I just thought it was normal for this clay.
I had a similar experience with my new bar...I found that you need to keep it moving. The longer your hot hand holds it the faster it peels apart. Also used a ton of detail spray and saw improved results. Yet it still sometimes becomes very sticky and peels apart in my hand similar to your picture
Regardless it works awesome removing contaminants... what better than my old mothers clay
