Texas Moe Posted May 11, 2015 Share Posted May 11, 2015 Used the In and Out Spray for the first time last week and got some blotches on the front grill and plastic trim. Just wondering if this is overspray or some other operator error. Also, is there any way to correct it? Link to comment Share on other sites More sharing options...
0 moparbrian Posted May 11, 2015 Share Posted May 11, 2015 I use that all the time and never had that happen. To me it looks like a reaction with something on there. It doesn't wipe off? Link to comment Share on other sites More sharing options...
0 Team Adam's Posted May 11, 2015 Share Posted May 11, 2015 Were the surfaces cleaned of any previously applied dressings? Could be a reaction with something there or a silicone dressing applied previously preventing it from sticking. The other possibility is it was held too close to the surface when you sprayed. The propellant contains solvents (all aerosols do) that evaporate a few inches from the tip of the nozzle, but if you hold it close to a surface when spraying the solvent hits the surface before it can evap so you end up with what is essentially a cleaner removing the dressing. Rich 1 Link to comment Share on other sites More sharing options...
0 Texas Moe Posted May 11, 2015 Author Share Posted May 11, 2015 Thanks for the feedback, car dudes. It could be any or all of the suggestions you made. I probably was holding the can close to the trim so as not to get it on anything else. Based on what y'all said, though, it's probably an interaction between the In & Out Spray and Quick Sealant. I was experimenting a few weeks ago with different parts of the exterior that could work with the QS. If that's the case, I have two questions: 1) How should I have removed any previous dressings before using the I&O spray? 2) Can I now do whatever is the answer to my first question and just start over? Thanks again! Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted May 11, 2015 Share Posted May 11, 2015 Scrub down with APC and a brush. Then start over. ledger64 1 Link to comment Share on other sites More sharing options...
Texas Moe
4 answers to this question
