Adams Fire Hose Nozzle..."Dual Gallonage"
LT1xL82
4 answers to this question
Maybe this will help you. Task Force Tips in Indiana makes Dual Gallonage Nozzles along with places like Elkhart Brass and Akron.
http://www.tft.com/productsearch/productgroup_details.cfm?productgroup=TWISTER%20SERIES
Basically it gives you two GPMs when twisting. Kind of hard to explain if I'm not there (I'm a hands on teacher).
Edited by Kingsford
Thank you for your replies.
I'm not sure mine works correctly...for starters it will not turn the water off completely. And it sprays at a slight angle. Looking from the front, the "valve and seat" are not concentric. Dealer says this is common. Not so sure that is acceptable. :)
As I twist the nozzle from closed (but leaking! :D) to full on it goes from shower mode, to stream, to a more distant stream. Presumably the later is the higher "gallonage" position?
