Zach5.9CTD Posted April 1, 2016 Share Posted April 1, 2016 Hey guys. Looking at buying an ozone generator to help aid in odor removal in vehicles. Found this unit on ebay for a good price. Anyone have any time with using this particular unit? http://pages.ebay.com/link/?nav=item.view&id=310856981714&alt=web Link to comment Share on other sites More sharing options...
0 blcksilv08 Posted April 2, 2016 Share Posted April 2, 2016 http://www.amazon.com/gp/aw/d/B00JAP7388/ref=mp_s_a_1_1?qid=1459561201&sr=8-1&pi=SY200_QL40&keywords=ozone+generator&dpPl=1&dpID=51EvhHadqBL&ref=plSrch Extremely similar to mine, the one I have works great for its size. Link to comment Share on other sites More sharing options...
0 Zach5.9CTD Posted April 2, 2016 Author Share Posted April 2, 2016 I actually found one on ebay that came with a waterproof case as well as an extra hex-tach ozone plate for 155 bucks Link to comment Share on other sites More sharing options...
0 blcksilv08 Posted April 2, 2016 Share Posted April 2, 2016 I actually found one on ebay that came with a waterproof case as well as an extra hex-tach ozone plate for 155 bucksNot a bad deal, I would give it a try. Link to comment Share on other sites More sharing options...
0 AmyAtAdamsAustralia Posted April 2, 2016 Share Posted April 2, 2016 (edited) Hi Zach, We looked into the possibility of using an Ozone generator for our detailing service in Australia. After some research we discovered some risks to using one. I understand that this article is taken from an Australian Government health website (other links for US at the end) but there are some points to consider no matter where you're located in the world. Ozone Generators Ozone generators are being promoted as an effective method to clean indoor air pollution and odours. However ozone is a lung irritant that can cause adverse health effects. Last updated: 13 May 2015 Introduction Ozone generators are being promoted as an effective method to clean indoor air pollution and odours. However ozone is associated with adverse health effects. Available scientific evidence shows that ozone concentrations that are safe to breathe are unlikely to be effective in controlling indoor air pollution. Manufacturers and vendors of ozone devices use a variety terms to describe ozone. Terms such as "energized oxygen" or "pure air" suggest that ozone is a "healthy" kind of oxygen. However, ozone is a toxic gas with very different properties to oxygen. Whether it is a pure form or mixed with other chemicals, ozone can be harmful to health. Ozone: Good up high, bad nearby Ozone, O3, is composed of three atoms of oxygen. Two atoms of oxygen form the basic oxygen molecule. The additional third atom makes ozone an unstable, highly reactive gas. The ozone layer in the upper atmosphere helps filter out damaging ultraviolet radiation from the sun, but ozone in the air we breathe is irritative to the eye, nose, throat and lungs and can have a significant negative impact on health. These proven adverse health effects have resulted in the Australian Government setting standards for ozone in outdoor air. What does an ozone generator do? An ozone generator is a device designed to produce the gas ozone. Ozone is used effectively in water purification, but ozone in air must reach high levels to remove air pollutants. Health experts warn that it is important to control conditions to ensure that no person or pet becomes exposed to high levels of ozone. Ozone also masks the odour of some pollutants by impairing a person's sense of smell. Further, ozone is not effective for killing bacteria or mould in materials such as air conditioning duct lining and ceiling tiles. Risks of using ozone generators Some people are more susceptible than others and may be more likely to experience adverse health effects. People at particular risk are children, the elderly and people with asthma.Exposure to ozoneCan cause eye, nose, throat and lung irritation, cough and shortness of breath. May exacerbate chronic respiratory diseases such as asthma. Is likely to increase hospital admissions and emergency room visits for respiratory disease. Can also adversely affect indoor plants, and damage materials such as rubber, electrical wire coatings, and fabrics. Some effective ways to control indoor air pollution There are several simple and effective methods of controlling indoor air pollution and odours, including source control, ventilation and air cleaning. It is important to note that mould is a common source of odours in homes. Source control is most effective and easy to implement: Remove products and materials, which cause indoor air pollution, or replace with an alternative non-polluting product. If no alternative product is available, store the polluting source elsewhere, for example paint thinners are best stored in a detached garage or shed. If you can not remove the source, try to reduce its strength. For example, sometimes formaldehyde-emitting materials such as MDF can be sealed to reduce the rate of emission. Do not allow people to smoke in your home. Routinely clean wet or moist surfaces to prevent mould and bacterial growth. Fix plumbing leaks and other water problems as soon as possible and dry all items completely. Separate damp areas from living areas and keep bathroom doors closed to reduce humidity in your home. For example vent clothes dryers to outside or locate the washing machine in a separate laundry. Ventilation is also effective and commonly used: Install an exhaust fan close to the source of pollutants or moisture such as the cooking stove, dishwasher and washing machine. Keep the windows open as often as possible to allow air to circulate. Run the bathroom fan or open the window when showering. Air cleaning by itself does not adequately reduce indoor air pollution, however it can be used in combination with source control and ventilation. Air filters, electronic particle air cleaners and ionizers can be used to remove airborne particles. Gas adsorbing material (eg activated charcoal) is sometimes used to remove gaseous pollutants. Air cleaners are relatively costly. To be effective they require proper sizing, installation and use (according to the manufacturers directions), and maintenance, so they are more suitable for use in workplaces rather than homes. Maintenance costs, such as replacement of filters, can be significant. If you choose to use an air cleaner such as an electrostatic precipitator or ionizer in your home or work, it is important to ensure that it does not produce ozone as a by-product. Further InformationDepartment of the California Environmental Protection Agency - Air Resources Board Health Canada: Consumer Product Warning National Environment Protection Measure for Ambient Air Quality - Air Quality Standards US Environmental Protection Agency: Ozone Generators that are Sold as Air Cleaners US Environmental Protection Agency: Sources of Indoor Air Pollution Improving Indoor Air Quality In NSW call 1300 066 055 to talk to your local Public Health Unit Edited April 2, 2016 by Joseph@AdamsAustralia mc2hill 1 Link to comment Share on other sites More sharing options...
0 pirahnah3 Posted April 2, 2016 Share Posted April 2, 2016 (edited) I have to agree with Joseph on this one. At work we have Ozone generators and we have a TON of safety precautions put in place to be able to work around them. I do realize that you will be using much smaller ones however it is still a fairly nasty creation if not handled properly. It works great as a deodorizer, de greaser, and a few other things but again it can be nasty stuff. For an idea we have air monitors in the room with the generator, an air monitor in the room we use it in (large tank dome), we have to wear personal air monitors in the area, and there are alarms and evacuation procedures if things go awry. I will say that once vented to atmosphere it does quickly dissipate and had no lingering effects once vented. Edited April 2, 2016 by pirahnah3 Link to comment Share on other sites More sharing options...
0 Zach5.9CTD Posted April 3, 2016 Author Share Posted April 3, 2016 Yeah. Well the vehicle would be unoccupied when running the machine and would be ventilated before removing the machine Ricky Bobby and Norton 2 Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted April 4, 2016 Share Posted April 4, 2016 ^this. Zach hit it on the head. Link to comment Share on other sites More sharing options...
0 Adam Posted April 4, 2016 Share Posted April 4, 2016 Great and thorough read here! Thanks to all, and Joseph, WOW, great info! AmyAtAdamsAustralia 1 Link to comment Share on other sites More sharing options...
0 AmyAtAdamsAustralia Posted April 4, 2016 Share Posted April 4, 2016 Yeah. Well the vehicle would be unoccupied when running the machine and would be ventilated before removing the machine That's fair enough. At the end of the day it would be a question of risk vs. reward, especially when running a business. Since the USA and Australia are highly litigious societies (among others) it pays to know the risks involved. Most of these OG machines are ineffective at killing mould and bacteria anyway, which is the main source of most putrid of smells. I guess I'm just cautious and can't justify using one, but that's me. mc2hill 1 Link to comment Share on other sites More sharing options...
0 Zach5.9CTD Posted April 7, 2016 Author Share Posted April 7, 2016 I'd only be breaking out the machine for smokers vehicles, or any other odor complaint Link to comment Share on other sites More sharing options...
0 blcksilv08 Posted April 7, 2016 Share Posted April 7, 2016 I'd only be breaking out the machine for smokers vehicles, or any other odor complaint That's the only time I ever use mine, smokers mostly. Change the HVAC filter as well. I only put the machine in after cleaning, steaming, extracting the interior, then I let it air out for several hours before occupying the vehicle. Link to comment Share on other sites More sharing options...
0 Rich Posted August 21, 2021 Share Posted August 21, 2021 19 hours ago, Jeremy098 said: I am down here in Crawfordville and have a Champion dual fuel two years old. No problems at all .I run on propane and marine gas , non ethanol. I have been thru many canes with generators . Just run for several hours in morn and several hours in eve . Hooking into house system has never been necessary for me as all I try to run is reffer and freezer . My pump will hold pressure for enuf to get thru the day . Shower at nite when generator is running . Another advantage to not hooking in to house is if I like my neighbors I can run their refrig for a couple hours . It is not necessary to run more than 5 or 6 hours a day . Where's Crawfordville? Link to comment Share on other sites More sharing options...
Zach5.9CTD
12 answers to this question
