Jknappen Posted May 14, 2016 Share Posted May 14, 2016 Would like to see your tire shine in an aerosol form. So much easier to use that spray bottle. Wont splash off onto wheels and you dont have to take the extra time to use a foam block to get it i to the little grooves and ribs on the tires. I can never seem to make it look uniform all the way around like I can with an aerosol. thequadfather 1 Link to comment Share on other sites More sharing options...
Fierce5 Posted May 14, 2016 Share Posted May 14, 2016 Agreed. That will make it a much better product Link to comment Share on other sites More sharing options...
LFairbanks Posted May 14, 2016 Share Posted May 14, 2016 Problem with aerosols is that they then need to comply to a whole bunch of regulations. That is why quick sealant went away. James__, jessewsmith, Antv20 and 2 others 5 Link to comment Share on other sites More sharing options...
PHOKUS Posted May 14, 2016 Share Posted May 14, 2016 As an alternative, try using a sponge to apply the tire shine. Spray the Tire Shine on the sponge, then apply to tire. Thinner sponge = higher gloss. Thicker sponge = Matte finish Antv20 1 Link to comment Share on other sites More sharing options...
The Guz Posted May 14, 2016 Share Posted May 14, 2016 Aerosols can also have overspray. Ricky Bobby 1 Link to comment Share on other sites More sharing options...
BluePoncho Posted May 14, 2016 Share Posted May 14, 2016 Anyone ever try those pump sprayers. My wife has one for kitchen oil. You pump the lid and it somehow pressurized the spray. Pretty darn close to aerosol Link to comment Share on other sites More sharing options...
Ricky Bobby Posted May 14, 2016 Share Posted May 14, 2016 Aerosols can also have overspray. Came in to post this ^^ Link to comment Share on other sites More sharing options...
rha600 Posted May 14, 2016 Share Posted May 14, 2016 I vote for something like this but in a simple spray. I have mud terrain tires that are a bitch to get into the lugs (on the side) with a sponge so a lot of the times I use the old school approach of VRT mixed with water but unless you knock it down with a sponge or towel it leaves it too shiny for my taste. I'd love to see a flat or almost flat look in a spray.And yeah, like others have said, the aerosols are a government nightmare. In and out spray was gone for a long time due to that. Link to comment Share on other sites More sharing options...
James__ Posted May 15, 2016 Share Posted May 15, 2016 For those of you who have a hard time getting the tire shine in shoulder lugs and other complicated spaces, try adding a small paint brush to your detailing supplies. It helps tremendously. jpenny902 1 Link to comment Share on other sites More sharing options...
James__ Posted May 15, 2016 Share Posted May 15, 2016 Link to comment Share on other sites More sharing options...
GXPaycheck Posted May 15, 2016 Share Posted May 15, 2016 Will it work in a Preval sprayer? http://www.homedepot.com/p/Preval-9-oz-Complete-Spray-Gun-267/202533738 Link to comment Share on other sites More sharing options...
rha600 Posted May 15, 2016 Share Posted May 15, 2016 I'm not sure if I need the brush, but I did just toss a MF block that I'm going to pull back out of the can and use for my tires. The will fix one of my biggest complaints which is the foam shredding. The brush is nice but not only will it take me forever but I think it will result in a shiny finish. I'm going to try the above video with my VRT and water mix. Next order I place will have some tire shine in it and I'll give that a try. Link to comment Share on other sites More sharing options...
James__ Posted May 16, 2016 Share Posted May 16, 2016 I'm not sure if I need the brush, but I did just toss a MF block that I'm going to pull back out of the can and use for my tires. The will fix one of my biggest complaints which is the foam shredding. The brush is nice but not only will it take me forever but I think it will result in a shiny finish. I'm going to try the above video with my VRT and water mix. Next order I place will have some tire shine in it and I'll give that a try. I would not use the brush to apply Tire Shine to the entire tire, only the shoulder blocks that are difficult to dress (this takes under 30 seconds per tire). The rest of the tire should still be dressed by spraying and leveling with a microfiber or foam block. Link to comment Share on other sites More sharing options...
Shaffer1 Posted May 16, 2016 Share Posted May 16, 2016 My sidewalls have a slotted design on them, I found using a foam brush makes it much easier to evenly apply the tire shine. The brushes usually come in bulk and I just toss them after a few applications. Link to comment Share on other sites More sharing options...
rha600 Posted May 16, 2016 Share Posted May 16, 2016 I would not use the brush to apply Tire Shine to the entire tire, only the shoulder blocks that are difficult to dress (this takes under 30 seconds per tire). The rest of the tire should still be dressed by spraying and leveling with a microfiber or foam block. There is absolutely zero possibility of you doing the lugs in under 30 seconds. Hell, watch the video that you posted, he spent more than 30 seconds just on 1/5 of that one tire. haha. Link to comment Share on other sites More sharing options...
James__ Posted May 16, 2016 Share Posted May 16, 2016 There is absolutely zero possibility of you doing the lugs in under 30 seconds. Hell, watch the video that you posted, he spent more than 30 seconds just on 1/5 of that one tire. haha. Also, the video was for demonstration purposes and he was speaking to explain what he was doing and why which causes it to take longer. As far as 'absolutely zero possibility' of doing them in under 30 seconds, I can speak from experience that it is absolutely possible, especially if the tires are clean. You may use a little more product so it spreads quicker, but even with tires > 35" I have no trouble doing it in that amount of time when I'm in a rush (minus 6-8" across the bottom of the tire that I tackle later after rolling the truck). Link to comment Share on other sites More sharing options...
rha600 Posted May 18, 2016 Share Posted May 18, 2016 I was actually just watching videos from, well lets just say a couple of "brothers" and the guy did almost the same exact tires on a Raptor. He used a brush but he used the bigger flag bristle wheel brush. Same idea but much bigger brush so of course that's going to cut down on time. Link to comment Share on other sites More sharing options...
