hockeybawler Posted May 23, 2016 Share Posted May 23, 2016 Can you mix apc with rinseless wash for a strip wash? I did a full strip wash the other day but havent had time to polish yet and want to make sure i got all the old sealant off. Link to comment Share on other sites More sharing options...
0 TheWolf Posted May 23, 2016 Share Posted May 23, 2016 If you already did a strip wash, then you should be fine to polish without strip washing again. If there are any areas where some sealant might remain, it won't cause any issue with the polishing. Link to comment Share on other sites More sharing options...
0 Jayco76 Posted May 23, 2016 Share Posted May 23, 2016 I have been contemplating doing this my self . So today I mixed up 4 gallons of rinceless wash and added 2oz of APC Did a full rinceless wash on my 2015 GMC Canyon SLT Then Clayed IT Followed by another rinceless wash with the same wash solution Worked like a charm Link to comment Share on other sites More sharing options...
0 hockeybawler Posted May 23, 2016 Author Share Posted May 23, 2016 I know I dont need to do it, I was just wondering if it can be done. Sounds good, I am going to give it a shot as well. Link to comment Share on other sites More sharing options...
0 James__ Posted May 23, 2016 Share Posted May 23, 2016 The problem with attempting a Strip Wash using Rinseless Wash which contains wax additives is that while you are washing with the intent of removing all of the existing LSPs, you are adding wax to the surface at the same time making it far less effective than strip washing with Car Shampoo which contains no wax... Kingsford and LT1xL82 2 Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted May 23, 2016 Share Posted May 23, 2016 Also if you are going to clay that will remove what might or might not be present. James__ 1 Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted May 23, 2016 Share Posted May 23, 2016 The problem with attempting a Strip Wash using Rinseless Wash which contains wax additives is that while you are washing with the intent of removing all of the existing LSPs, you are adding wax to the surface at the same time making it far less effective than strip washing with Car Shampoo which contains no wax... You can definitely use APC in your Rinseless wash to strip - the APC will cancel out the wax additive so it would be stripped nicely - I have done it before and it works well. Link to comment Share on other sites More sharing options...
hockeybawler
6 answers to this question
