Erictski Posted February 18, 2017 Share Posted February 18, 2017 Curious if the sk mini could tackle a whole vehicle for wax or sealant application? I know it isn't meant for whole car correction, but seeing as how spreading wax and sealant is a quicker less taxing job was wondering if it would be possible. Link to comment Share on other sites More sharing options...
0 jessewsmith Posted February 18, 2017 Share Posted February 18, 2017 Yes it'll do just fine Link to comment Share on other sites More sharing options...
0 chops1sc Posted February 18, 2017 Share Posted February 18, 2017 I use my full size DA and a black 5" pad to spread PS Link to comment Share on other sites More sharing options...
0 Dwhite0960 Posted February 18, 2017 Share Posted February 18, 2017 It will work great and the mini will fit a pot of paste wax easily Link to comment Share on other sites More sharing options...
0 Geebee Posted February 18, 2017 Share Posted February 18, 2017 I tried to use the mini for paste wax, but I found the lowest speed a little too fast for an even application. I use my cordless drill with the Adam's cordless backing plate and the black pad to be my best option. I can vary the speed during the wax application to my needs....(my 2 cents) Link to comment Share on other sites More sharing options...
0 Dan@Adams Posted February 18, 2017 Share Posted February 18, 2017 If you use the Adam's Swirl Killer Mini for wax or sealant application, the lowest speed setting of 1 is 2,500 OPM vs 2,000 OPM of the regular Swirl Killer, so it will oscillate a bit faster even at the lowest setting - it's manageable but like Gary said, it may not work best for you in this particular application. The Swirl Killer Mini is designed as more of a spot correction machine for imperfections in tight areas - wait until you see some of the correction work it's done on this Silverado I'm working on at my house now! I'll be posting a write-up hopefully soon when the truck is complete. Also, if you use the Swirl Killer Mini for wax or sealant application, I would recommend doing one panel at a time, with no downward pressure on the paint. Chris@Adams 1 Link to comment Share on other sites More sharing options...
0 Erictski Posted February 18, 2017 Author Share Posted February 18, 2017 Thanks. Part two of my question would be; is Adam's paint sealant approved for use with the large swirl killer? I ask because my current sealant of choice is for 8mn da only or hand application. Link to comment Share on other sites More sharing options...
0 Dan@Adams Posted February 18, 2017 Share Posted February 18, 2017 Yes the Swirl Killer is absolutely fine to use for applying our Paint Sealant with our 6" Gray Foam Pad. Run it at around speed 2 and apply it thin and even and you'll be good to go! Link to comment Share on other sites More sharing options...
0 Erictski Posted March 24, 2017 Author Share Posted March 24, 2017 If you use the Adam's Swirl Killer Mini for wax or sealant application, the lowest speed setting of 1 is 2,500 OPM vs 2,000 OPM of the regular Swirl Killer, so it will oscillate a bit faster even at the lowest setting - it's manageable but like Gary said, it may not work best for you in this particular application. The Swirl Killer Mini is designed as more of a spot correction machine for imperfections in tight areas - wait until you see some of the correction work it's done on this Silverado I'm working on at my house now! I'll be posting a write-up hopefully soon when the truck is complete. Also, if you use the Swirl Killer Mini for wax or sealant application, I would recommend doing one panel at a time, with no downward pressure on the paint. Yes the Swirl Killer is absolutely fine to use for applying our Paint Sealant with our 6" Gray Foam Pad. Run it at around speed 2 and apply it thin and even and you'll be good to go! These two statements conflict a bit maybe you could clarify. You said the SK is slower on speed 1 than the SK mini, but here you tell me to use setting 2 on the SK for sealant. wouldn't speed 1 on the Mini be slower or equal to that of the SK on setting TWO? I am specifically talking sealants and not waxes as I don't use paste waxes, just adams sealant and another sealant that recommends not using a long throw machine to apply. thanks for any clarification you give. Link to comment Share on other sites More sharing options...
0 Dan@Adams Posted March 24, 2017 Share Posted March 24, 2017 These two statements conflict a bit maybe you could clarify. You said the SK is slower on speed 1 than the SK mini, but here you tell me to use setting 2 on the SK for sealant. wouldn't speed 1 on the Mini be slower or equal to that of the SK on setting TWO? I am specifically talking sealants and not waxes as I don't use paste waxes, just adams sealant and another sealant that recommends not using a long throw machine to apply. thanks for any clarification you give. The larger 5.5" pads and longer orbit movement of the Swirl Killer will oscillate on the surface a little more slowly at a speed setting or 1 or 2 when compared to the smaller 4" pad and slightly smaller orbit movement on the Swirl Killer Mini. While you don't need to use downward pressure when applying a sealant or wax with a machine, the pad is still contacting the surface and creating some amount of drag, even if minimal. A larger surface area pad seems to create more drag to me than a smaller pad. I've done no scientific measurements for this observation other than hours of polishing and use with both machines. Speed 2 on the Swirl Killer Mini does not correspond equally to speed 2 on the regular Swirl Killer, if you use both machines side by side with the same pads and sealant. If you test it out you will see what I mean. Speed 1 on the Swirl Killer Mini spins the pads at 2500 OPM, which is the same speed as setting 2 on the Swirl Killer as you had mentioned. You can try using the Swirl Killer Mini for sealant application, and it should give you pretty good results if running it on speed 1, just make sure to spread it around a lot before powering on the machine to avoid unnecessary slinging of sealant. For me personally, I can seal small areas by hand almost just as quickly as I would with the Swirl Killer Mini. I do however, still use the normal Swirl Killer to apply Paint Sealant to large body panels, since it provides consistent, even, and thin application of the product. Erictski 1 Link to comment Share on other sites More sharing options...
0 Erictski Posted March 25, 2017 Author Share Posted March 25, 2017 Thanks dan. Clears it up a bit. But no issues with the paint sealant and the sk15. Good to know Link to comment Share on other sites More sharing options...
Erictski
10 answers to this question
