I did a quick search on here, but couldn't find a 'defined' answer for this. I have ordered my first polisher (12mm Shinemate DA, not Adam's as we don't have access to them here in Aus yet - hint hint!) and it comes with a couple of pads. I have some Adam's 5" pads on order, and I was wondering if there is any special procedure for the very first time you use the pad. Do you have to prime them with anything before using them, or are they good to use straight out of the packaging? I know many people use a shot of detail spray or distilled water to help reactivate previous polish in the pad when they are in use, but no real instructions on the first time using the pads from brand new.
I have read about some 'other' brand pads needing to be primed and used lubricated for the first few passes to reduce the chance of pad and foam dust, and failing to do so can lead to a fair amount of dust and foam particles being thrown everywhere until the pad wears in. I would like to avoid this and also avoid causing any damage to my paintwork in the process - as I have never used a polisher before
joelilton23
Hey Guys,
Any advice would be much appreciated!
Edited by joelilton23Link to comment
13 answers to this question
