So I think its finally time to detail my Ram. It doesnt fit in the garage so its always outside. We have very hot summers reaching about 115* on a normal basis, and for work I constantly have to drive next to fields and that means a lot of bugs and pebbles. So it has taken a lot of abuse over time, but since its silver, it doesnt look so bad from a few feet.
I detail the interior a lot more often than the exterior so luckily everything inside is in good shape. Not too long ago, I went fishing and drove through a rough path with thick bushes and tree branches sticking out and ended up getting my drivers side door scratched up. So I decided now would be a good time to do the whole truck.
I wash the truck about every 2 or 3 weeks. Sometimes less when I use my other car instead. I use the two bucket system and Adams shampoo and wash mitt. On every wash I use APC on the tires and a VRT on all the black plastic trim. As for the rims I also use adams shampoo but about every second or third wash, Ill use deep wheel cleaner. And ill also use h2o guard and gloss about every month.
So this weekend I ordered more products and I was thinking of changing the routine:
1) Clean all 4 tires with tire cleaner. It says it works on trim too, so Ill also use this for all the plastic trim
2) clean all 4 wheels with deep wheel cleaner (I still have a full gallon of the older pink one)
3) Wash the truck with strip wash using the 2 bucket method. (Go back and clean the wheel wells at the end)
4) Dry the whole car and use VRT on trim and tire shine/undercarriage spray on the wheels.
5) Clay bar the whole car.
6) Use polish and my DA polisher to try and get rid of the scratches on the drivers side. (I was gifted a bit of a different brands polish and finish so i figured id try it now. If it doesnt work, ill order adams heavy correcting compound.)
7) use the finishing compound on the rest of the truck (these two are the only items of a different brand ill be using for this)
8) Apply Liquid paint sealant to the rest of the car.
9) Top it off with Buttery Wax
My question is, I also have some old Brilliant Glaze that im considering adding. At what point should I add the glaze? or would you guys skip on it?
I really wanted to try the ceramic trim and paint coating but Im saving that for later when my other car is ready so I can apply it on both. For now I still have a full bottle of VRT that I need to use.
Let me know what you guys think and if im missing something or should switch some stuff around.
Chonke
Thanks!
