Ryobi 2800psi / 2.3gpm
gymrat7953
 Share
14 answers to this question
I have the greenworks 2000 psi, mine works great with Adams foam cannon, and I think the companies ryobi and greenworks are similar, so I think you will be fine, I looked at the picture and it looks like 1/4 in disconnect, but I cannot confirm anything, sorry!
Your fine no adapter modifications are needed for your setup with the ryobi pressure washer. That's a good choice for a pressure washer and comes with a good warranty better than most!
I'm buying a Ryobi pressure washer; spec in the title block. Will the Adams foam canon work with it?
Any adapter / modifications needed?
Thanks
That is the exact pressure washer I use with my foam cannon and it works great. The only modification I did to mine was I replaced the long wand with a short one, reason being with a long wand it feels like you are carrying a weight on the end of a pole.
Answer this question...
 Share
