Solobaric Posted June 12, 2017 Share Posted June 12, 2017 (edited) I've seen videos showing both methods but I just want to make sure. I can apply the paint finishing polish directly on top of hazed paint correcting polish correct? I don't have to buff off the residue before I apply the PFP do I? Edited June 12, 2017 by Solobaric Link to comment Share on other sites More sharing options...
0 07stanggt Posted June 12, 2017 Share Posted June 12, 2017 I have never done that before ! I remove all correcting polish first then apply finishing polish after I have seen the results. If it needs more correcting, how would you know that unless you wiped off the correcting polish first? Link to comment Share on other sites More sharing options...
0 vobro Posted June 12, 2017 Share Posted June 12, 2017 I too remove the compound as I go Link to comment Share on other sites More sharing options...
0 red94chev Posted June 12, 2017 Share Posted June 12, 2017 I have polished directly over the leftover from correcting polish residue but I prefer to wipe it off and do a quick inspection before moving to the next step. zapdon 1 Link to comment Share on other sites More sharing options...
0 Kingsford Posted June 12, 2017 Share Posted June 12, 2017 I'd remove it before continuing in for a few reasons. For one you'll be able to see if you're happy with your results from CP or if you need to go over it again. Another reason would be, if you went over it with a white pad and FP it could potentially clog up your pad faster. Link to comment Share on other sites More sharing options...
0 shane@detailedreflections Posted June 12, 2017 Share Posted June 12, 2017 (edited) I will go right over correcting polish...sometimes. To find the process I need, I'll work a small section wiping away each step to see the results. Once I've settled on a process, I go through and do the whole vehicle. I will wipe away in areas of heavy damage where I'm really working to get the damage out. The other time I'll wipe away is if it's really warm or cold out. That way it wipes easier. The choice to buff off every step or not is up to you. Sometimes we do. Sometimes we don't. It depends on what we're trying to accomplish and how much time we have dedicated to the job. There is no right or wrong answer in this case. Edited June 12, 2017 by medic001918 Link to comment Share on other sites More sharing options...
0 pirahnah3 Posted June 13, 2017 Share Posted June 13, 2017 I usually go right over it every time. Ill do a tiny section at times to see if I should have it covered but typically its just go around the vehicle once, change pads and bottle and back around we go. Link to comment Share on other sites More sharing options...
Solobaric
Edited by SolobaricLink to comment
6 answers to this question
