mathews31 Posted June 13, 2017 Share Posted June 13, 2017 (edited) A few weeks ago I heard Matt from Obsessed Garage saying you can polish glass, I tried yesterday with the SK and the blue correcting compound. But I didn't notice any difference. Anyone have any experience with that? Edited June 14, 2017 by mathews31 Link to comment Share on other sites More sharing options...
0 mc2hill Posted June 14, 2017 Share Posted June 14, 2017 You can polish glass, but only water spots. For anything more you need different products and pads. ocdrifter 1 Link to comment Share on other sites More sharing options...
0 pirahnah3 Posted June 14, 2017 Share Posted June 14, 2017 What goal are you looking to achieve? I have heard you can use pads and some prodcuts to do it, but I personally have had great luck with just #0000 steel wool over either detail spray or glass cleaner. PacificNWBuckeye 1 Link to comment Share on other sites More sharing options...
0 GXPaycheck Posted June 14, 2017 Share Posted June 14, 2017 There are glass polishing products out there. SumBeach35 1 Link to comment Share on other sites More sharing options...
0 PacificNWBuckeye Posted June 14, 2017 Share Posted June 14, 2017 I don't believe the Adam's line is abrasive enough to be very effective on glass, but as Jim noted above #0000 Steel Wool with glass cleaner will knock down most stubborn items from glass with no ill effects. Link to comment Share on other sites More sharing options...
0 LT1xL82 Posted June 14, 2017 Share Posted June 14, 2017 Glass is much harder than paint. If you're trying to remove defects like scratches...it will take different pads and polish. A messy job BTW. Link to comment Share on other sites More sharing options...
0 Greg from GA Posted June 14, 2017 Share Posted June 14, 2017 I used clay and the orange pad and polish to get water spots off. Seemed to work fine. LT1xL82 1 Link to comment Share on other sites More sharing options...
0 azscj Posted June 19, 2017 Share Posted June 19, 2017 I just went over the glass on my Ford F250 with a clay bar but still have some hard water spots I want to remove in some areas. I bought Adams glass cleaner and sealant, but probably need to try to remove the water spots first. The 0000 steel wool and glass cleaner works to remove the water spots? Someone here has had luck with that? Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted June 20, 2017 Share Posted June 20, 2017 I just went over the glass on my Ford F250 with a clay bar but still have some hard water spots I want to remove in some areas. I bought Adams glass cleaner and sealant, but probably need to try to remove the water spots first. The 0000 steel wool and glass cleaner works to remove the water spots? Someone here has had luck with that? I always use HCC & Blue MF pad to remove water spots on glass. Link to comment Share on other sites More sharing options...
0 Mariner Posted June 20, 2017 Share Posted June 20, 2017 If the spots aren't too far gone, Revive Hand Polish and the blue hex grip work just fine for me. Link to comment Share on other sites More sharing options...
0 azscj Posted June 20, 2017 Share Posted June 20, 2017 Ok..thanks for the responses. So those are both Adams products so I can give them a try. I assume you are doing this by hand and not using a machine on the glass? Link to comment Share on other sites More sharing options...
0 chops1sc Posted June 20, 2017 Share Posted June 20, 2017 Ok..thanks for the responses. So those are both Adams products so I can give them a try. I assume you are doing this by hand and not using a machine on the glass? You would want to use a machine for this. Link to comment Share on other sites More sharing options...
0 Mariner Posted June 20, 2017 Share Posted June 20, 2017 Ok..thanks for the responses. So those are both Adams products so I can give them a try. I assume you are doing this by hand and not using a machine on the glass? I apply RHP by hand. But then again, I usually catch my water spots a day or two after I notice them. If you wait too long, they get much worse. Link to comment Share on other sites More sharing options...
mathews31
Edited by mathews31Link to comment
12 answers to this question
