hemi1300 Posted December 23, 2017 Share Posted December 23, 2017 Curious how safe rinseless is with some slight salt spray on the vehicle, or should you always pressure wash first to remove as much salt as possible before rinseless? Link to comment Share on other sites More sharing options...
0 BrianT Posted December 23, 2017 Share Posted December 23, 2017 The only issue I see is the rinselesswash might dissolve some of the salt so you might want to see if you need to do a second pass. Link to comment Share on other sites More sharing options...
0 LSX Maestro Posted December 23, 2017 Share Posted December 23, 2017 There's no way I could just go straight to a rinseless without doing damage to the clear coat with my truck and our Michigan roads. I have the lucky situation of being less than 2 miles away from a quarter car wash so on dryish days I take it up there, pay $4 and power wash every single bit I can off the truck. On days where I'm tight on time, that can even be enough after I use air to dry it off at my garage. A rinseless takes it from being pretty clean to sparkly shiny white. Link to comment Share on other sites More sharing options...
0 Nickfire20 Posted December 24, 2017 Share Posted December 24, 2017 I know this is a rinseless question, but yesterday i did a waterless on my black truck. it had been cleaned, polished, sealed a few days ago. But then i drove on dry roads and got some salt dust on the truck. When i did the waterless, i had white smearing everywhere!!! Huge head ache! Took multiple more passes to fix. So, i just have to live with the dust now, or do a full 2bucket again. Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted December 24, 2017 Share Posted December 24, 2017 On 12/22/2017 at 7:39 PM, hemi1300 said: Curious how safe rinseless is with some slight salt spray on the vehicle, or should you always pressure wash first to remove as much salt as possible before rinseless? Yes I would pressure wash all the Winter junk off first. Then you can do a RW or WW. Link to comment Share on other sites More sharing options...
0 8675309'SS Posted December 24, 2017 Share Posted December 24, 2017 14 hours ago, LSX Maestro said: There's no way I could just go straight to a rinseless without doing damage to the clear coat with my truck and our Michigan roads. I have the lucky situation of being less than 2 miles away from a quarter car wash so on dryish days I take it up there, pay $4 and power wash every single bit I can off the truck. + 1. OP. Spray off whatever you can first. I tried 2 doors top to bottom once to experiment, it was not as sound a method as spraying first. I am about 10 blocks from a spray place. I don't the use their soap, just water. I let the water run through the sprayer for several seconds to clear out whatever the person before me ordered up, i.e engine cleaner, wax, soap. After the the pay n spray, I do a rinseless in my driveway, using bucket of towels method. I also typically spray the lower 1/4 of the car with rinseless diluted 16:1 and let it dwell while I am doing the upper parts of the car. For new people reading this thread, other dilution ratios here: Link to comment Share on other sites More sharing options...
0 LSX Maestro Posted December 24, 2017 Share Posted December 24, 2017 2 hours ago, 8675309'SS said: + 1. OP. Spray off whatever you can first. I tried 2 doors top to bottom once to experiment, it was not as sound a method as spraying first. I am about 10 blocks from a spray place. I don't the use their soap, just water. I let the water run through the sprayer for several seconds to clear out whatever the person before me ordered up, i.e engine cleaner, wax, soap. After the the pay n spray, I do a rinseless in my driveway, using bucket of towels method. I also typically spray the lower 1/4 of the car with rinseless diluted 16:1 and let it dwell while I am doing the upper parts of the car. For new people reading this thread, other dilution ratios here: That’s exactly what I do, including the wait until you have straight water. I haven’t tested with Adam’s PS and I’m not going to but when I used to use a cheaper wax on my truck, and washed it at the quarter car wash, I used the presoak and it stripped most of the wax off. Water only! Commercial stuff is nasty. Link to comment Share on other sites More sharing options...
hemi1300
6 answers to this question
